Hello! I recently bought a WCH model 0333 mechanical bell and as you can see in the picture, the diagram is very damaged. You can not see it. I would like to make it work but I have no idea what sides are positive and negative. Also, there is a crack in the back, as you can also see in the picture. I was wondering how to fix it. David Prince advised me to weld the back cover. Are there other possible solutions? I do not understand how this bell cracked. It was in Bradenton, Florida.
My WCH mechanical bell (0333)
Southwest Quebec Railfan
Proud owner of 3 crossing bells (WCH 0333, Safetran mechanical and WRRS mini-bell) and a WRRS 8'' light.
My YouTube Channel: https://www.youtube.com/channel/UCUSubL ... mxJ5WtNaQ/
My Facebook Page: http://www.facebook.com/southwestquebecrailfan
Re: My WCH mechanical bell (0333)
Oh wow, that's pretty neat to see a WCH bell that's not on a "stair" base like most of them.
Nice bell, and welcome to the boards first off.Railtrack wrote:Hello! I recently bought a WCH model 0333 mechanical bell and as you can see in the picture, the diagram is very damaged. You can not see it. I would like to make it work but I have no idea what sides are positive and negative. Also, there is a crack in the back, as you can also see in the picture. I was wondering how to fix it. David Prince advised me to weld the back cover. Are there other possible solutions? I do not understand how this bell cracked. It was in Bradenton, Florida.
Wiring the bell is quite easy as the wires go to the black module on the bottom right on the inside. The positive wire goes to the one on the left and the negative wire goes to the one in the middle.
Thanks! This bell has a WRRS base.ZachL wrote:Oh wow, that's pretty neat to see a WCH bell that's not on a "stair" base like most of them.
Thanks!LARDLOGO wrote:Nice bell, and welcome to the boards first off.Railtrack wrote:Hello! I recently bought a WCH model 0333 mechanical bell and as you can see in the picture, the diagram is very damaged. You can not see it. I would like to make it work but I have no idea what sides are positive and negative. Also, there is a crack in the back, as you can also see in the picture. I was wondering how to fix it. David Prince advised me to weld the back cover. Are there other possible solutions? I do not understand how this bell cracked. It was in Bradenton, Florida.
