Google Maps Scavenger Hunt (Traffic signals and signs)
- Erik-Gorb-Hamilton
Re: Google Maps Scavenger Hunt (Traffic signals and signs)
Continuing my
Grandfathers
Legacy
CEO of the Stratford Gap Railway
Grandfathers
Legacy
- NathanFromEngland
Signals on masts, you don't see this in the UK often!
https://www.google.com/maps/@53.4440932 ... 312!8i6656
https://www.google.com/maps/@53.4437,-2 ... 312!8i6656
https://www.google.com/maps/@53.4441993 ... 312!8i6656
Very old Plessy signals!
https://www.google.com/maps/@53.4455741 ... 312!8i6656
This signal however has a Motus head installed at it.
https://www.google.com/maps/@53.4458992 ... 312!8i6656
Signal for bikes.
https://www.google.com/maps/@53.4485413 ... 312!8i6656
If you look at the middle of this road, you can see that it replaced a roundabout in recent years.
https://www.google.com/maps/@53.4538975 ... 312!8i6656
A bunch of strange looking signs placed on a bridge a few years ago.
https://www.google.com/maps/@53.4593297 ... 312!8i6656
https://www.google.com/maps/@53.4593701 ... 312!8i6656
https://www.google.com/maps/@53.4594229 ... 312!8i6656
https://www.google.com/maps/@53.4594632 ... 312!8i6656
Signal for bikes.
Nice find! The main street appears to use yellow lenses, which could've been done back when the signal was installed.Erik-Gorb-Hamilton wrote:Was probably a 4 way stop at one time...
ftfyNathanFromEngland wrote:Signals on cantilevers, you don't see this in the UK often!
Technically, what traffic lights are mounted on is officially referred to as "mast arms". Cantilevers are what's used at crossings (save for the crossings that use mast arms, or the traffic lights that use cantilevers...).ZachL wrote:ftfyNathanFromEngland wrote:Signals on cantilevers, you don't see this in the UK often!
- NathanFromEngland
I can't believe i just tricked myself into thinking i put cantilevers in my post.freebrickproductions wrote:Technically, what traffic lights are mounted on is officially referred to as "mast arms". Cantilevers are what's used at crossings (save for the crossings that use mast arms, or the traffic lights that use cantilevers...).ZachL wrote:ftfyNathanFromEngland wrote:Signals on cantilevers, you don't see this in the UK often!
- NathanFromEngland
Found a photo of this junction not far from my house that was taken in the 80's. It had tin lantern signals at them, before being upgraded presumably in the mid to late 80's. It used to have a pedestrian crossing that just got replaced by pedestrian signals when the junction was overhauled.
Unfortunately, this was the only image i could find.
https://www.flickr.com/photos/44435674@N00/449439872
Heres a picture of the signals in June 2014. By then, the backboards had faded, the pedestrian pushbuttons color were fading and the signals were starting to rust.
https://www.google.com/maps/@53.4252179 ... 312!8i6656
The following month in July, the junction was overhauled.
https://www.google.com/maps/@53.4252178 ... 312!8i6656
On the topic of Tin Lanterns, this was the last junction in Tin Lantern existence to be sole survivors, they were finally removed in 2001 and replaced by these signals.
https://www.google.com/maps/@53.3796191 ... 312!8i6656
A guy used to have a bunch of photos of the tin lantern signals that were taken around 1999, but he deleted all the photos for some reason.
Makes sense although I kinda don't understand why the distinguishing exists considering it's the same concept crossing or notfreebrickproductions wrote:Technically, what traffic lights are mounted on is officially referred to as "mast arms". Cantilevers are what's used at crossings (save for the crossings that use mast arms, or the traffic lights that use cantilevers...).ZachL wrote:ftfyNathanFromEngland wrote:Signals on cantilevers, you don't see this in the UK often!
- ToledoRailfan
It might be because mast arms are just arms coming off the mast while cantilevers are more of a structure.ZachL wrote:Makes sense although I kinda don't understand why the distinguishing exists considering it's the same concept crossing or notfreebrickproductions wrote:Technically, what traffic lights are mounted on is officially referred to as "mast arms". Cantilevers are what's used at crossings (save for the crossings that use mast arms, or the traffic lights that use cantilevers...).ZachL wrote:ftfyNathanFromEngland wrote:Signals on cantilevers, you don't see this in the UK often!
- NathanFromEngland
Some very old 1950's Concrete Utilites lamp posts, however it looks that the lamps were modernized in the 1980's with metal brackets and Philips MA50's
https://www.google.co.uk/maps/@53.49014 ... 312!8i6656
GSV caught some work going on with the installation of a new pole for a street lamp!
https://www.google.co.uk/maps/@53.48999 ... 312!8i6656
Sadly, the new streetlamp only lasted 7 years, as it was replaced in early 2016.
https://www.google.co.uk/maps/@53.49006 ... 312!8i6656
