Lily Flagg Road, Huntsville, AL
Post by freebrickproductions » Wed Feb 03, 2016 3:54 pm
Signal on the left: 2 pairs of WRRS 8 inch lights.
Signal on the right: 2 pairs of WRRS 8 inch lights.
The bell is a Safetran mechanical bell mounted on the relay case.
Re: Lily Flagg Road, Huntsville, AL
Post by freebrickproductions » Fri Mar 25, 2016 11:14 pm
Got another video from the other side yesterday, this time with one of the HMCR's new B39-8s making an appearance!
Post by freebrickproductions » Wed Jun 01, 2016 1:01 pm
Sounds like the bell was slowed down a bit since I was last here.
Post by freebrickproductions » Thu Oct 06, 2016 4:19 pm
Post by freebrickproductions » Sat Nov 19, 2016 5:02 pm
And this time around, we get two B39-8s running lite.
Post by freebrickproductions » Wed Dec 07, 2016 10:22 pm
The damaged light has recently fallen off of the signal:
If you look closely, you can see the fallen WRRS 8 inch light next to the bottom of the signal.
The HMCR might not replace the damaged light as they have a brand new mast signal that's being shipped to replace the one on the right in the video.
Post by freebrickproductions » Mon Jan 16, 2017 7:57 pm
Still missing a light:
The new signal to replace the damaged one has arrived, but the HMCR hasn't had time to install it yet.
Post by freebrickproductions » Sat Jul 22, 2017 1:36 am
The Parkway's construction is advancing nicely. Video from July 19th, 2017:
Post by freebrickproductions » Sun Jan 14, 2018 3:26 pm
Still has the damaged signal:
However, the new signal may be installed by the end of the year as the construction on the Parkway is a year ahead of schedule.
Post by freebrickproductions » Thu Dec 27, 2018 9:38 pm
*originally recorded on 12-13-18*
The bell is a Safetran mechanical bell located on the relay case.
The only change to this crossing since I last recorded it was that a WRRS 8 inch light was installed on the near signal here a few months back. The light was re-used from Bob Wallace Avenue.
http://www.rxrsignals.com/Alabama/G-Q/H ... Lily_Flagg
