Google Maps Scavenger Hunt
- NathanFromEngland
Safetran Type 3 in Sanger, California.
https://www.google.com/maps/@36.7131419 ... 6656?hl=en
Refer to me as 'Nari' - She/They are my preferred pronouns
I'm more interested in those classic WRRS signals.NathanFromEngland wrote:Safetran Type 3 in Sanger, California.
- NathanFromEngland
- ToledoRailfan
Active crossing in Köniz, Canton of Bern.
https://www.google.com/maps/@46.9175749 ... 6656?hl=en
Visibility! Looks like an incline there on approachNathanFromEngland wrote:
https://www.google.com/maps/@45.4687649 ... 6656?hl=en
- NathanFromEngland
Crossbuck on display?
https://www.google.co.uk/maps/@44.07595 ... 312!8i6656
Ruined buckseye crossbuck setup.
https://www.google.co.uk/maps/@44.06765 ... 312!8i6656
Again, another ruined crossbuck setup.
https://www.google.co.uk/maps/@44.11063 ... 312!8i6656
Abandoned tracks.
https://www.google.co.uk/maps/@44.13189 ... 312!8i6656
What's this?
https://www.google.co.uk/maps/@44.24490 ... 312!8i6656
Defect detector.
https://www.google.co.uk/maps/@44.26768 ... 312!8i6656
Abandoned tracks.
What's this?
Defect detector.
- ToledoRailfan
Looks like there was a crossing there.NathanFromEngland wrote:Crossbuck on display?
https://www.google.co.uk/maps/@44.07592 ... 328!8i1664
That isn't a *Buckeye crossbuck setup. Buckeye crossbuck setups were only an Ohio thing, hence why they were called Buckeye. Those shields are just a similar thing that are standard for passive crossings in Idaho.NathanFromEngland wrote: Ruined buckseye crossbuck setup.
Although I did once find (on Google streetview) a pair of those shields in Washington for some reason.
https://www.google.com/maps/@48.2700672 ... 6656?hl=en
Looks like that hasn't been used for decades! Looks like someone is trimming the vegetation at the end of the track!NathanFromEngland wrote: Abandoned tracks.
Although you should've posted that in this thread.
viewtopic.php?f=13&t=1596&start=1440
Not a defect detector. Defect Detectors are located between and around the rails. Those detectors that you posted are for making sure that the cars on a train should actually be there (IIRC).NathanFromEngland wrote: Defect detector.
It's very much possible that those were imported from Idaho, and it'd make sense considering how close that line is to state lines (not close-close, but close enough )ToledoRailfan wrote:Although I did once find (on Google streetview) a pair of those shields in Washington for some reason.
- ToledoRailfan
I thought about that, they probably came with the crossbuck posts.ZachL wrote:It's very much possible that those were imported from Idaho, and it'd make sense considering how close that line is to state lines (not close-close, but close enough )ToledoRailfan wrote:Although I did once find (on Google streetview) a pair of those shields in Washington for some reason.
