Lily Flagg Road, Huntsville, AL
Re: Lily Flagg Road, Huntsville, AL
Recorded the eastern side on 4-26-19, with no changes to report:
No major changes as of 7-6-20, though the lights did get a fresh coat of paint:
*originally recorded on 7-15-21*
Signal on the left: 2 pairs of WRRS 8 inch lights with Electro-tech LEDs.
Signal on the right: 2 pairs of WRRS 8 inch lights.
The bell is a Safetran mechanical bell mounted on the relay case.
This was the second crossing I caught the HMCR at. As you can see, in the past year since I last recorded this crossing, the HMCR has given the far signal an LED upgrade, but thankfully they chose to use 8 inch LEDs rather than replacing the lights with 12 inch ones. The other signal, as you can see, is still fully incandescent though, nor has there been any other major changes to the signals here, thankfully.
http://www.rxrsignals.com/Alabama/G-Q/H ... ily_Flagg/
No changes as of 11-7-21:
Finally got the side with the 8 inch Electro-tech LEDs recorded, with no changes as of 11-21-21:
No changes here as of 5-4-22:
Still the same as of 9-6-23:
Got another video here on 1-24-24:
And another on 3-13-24:
