Correct. A Safetran Type-2 e-bell has an exposed area on the base, whereas an NEG e-bell has a metal ring around the base.freebrickproductions wrote: Actual Safetran Type 2s are. NEGs are just about a dime a dozen, especially on the CSX and UP. Other than a different base on a few of them, they are also exactly alike the Safetran Type 2s, AFAIK..
Do they still make Safetran Bells?
Re: Do they still make Safetran Bells?
Pages 11-12 here:nickrink wrote:Does anyone know where I can view bells on Siemens website?
https://w3.usa.siemens.com/mobility/us/ ... oducts.pdf
Pages 3-6 here:
https://w3.usa.siemens.com/mobility/us/ ... ystems.pdf
Actually, NEG and Safetran Type 2s are exactly the same externally. UP just likes to put metal rings around the bases of theirs. However, some NEG e-bells have a very similar base to that of a General Signals e-bell.ZachL wrote:Correct. A Safetran Type-2 e-bell has an exposed area on the base, whereas an NEG e-bell has a metal ring around the base.freebrickproductions wrote: Actual Safetran Type 2s are. NEGs are just about a dime a dozen, especially on the CSX and UP. Other than a different base on a few of them, they are also exactly alike the Safetran Type 2s, AFAIK..
I guess you're right, although for a while it almost looked like CSX was doing the same:freebrickproductions wrote:Actually, NEG and Safetran Type 2s are exactly the same externally. UP just likes to put metal rings around the bases of theirs. However, some NEG e-bells have a very similar base to that of a General Signals e-bell.ZachL wrote:Correct. A Safetran Type-2 e-bell has an exposed area on the base, whereas an NEG e-bell has a metal ring around the base.freebrickproductions wrote: Actual Safetran Type 2s are. NEGs are just about a dime a dozen, especially on the CSX and UP. Other than a different base on a few of them, they are also exactly alike the Safetran Type 2s, AFAIK..
https://www.google.com/maps/@28.033038, ... 312!8i6656
That's probably what it's mounted on showing through the base.ZachL wrote:I guess you're right, although for a while it almost looked like CSX was doing the same:freebrickproductions wrote:Actually, NEG and Safetran Type 2s are exactly the same externally. UP just likes to put metal rings around the bases of theirs. However, some NEG e-bells have a very similar base to that of a General Signals e-bell.ZachL wrote:Correct. A Safetran Type-2 e-bell has an exposed area on the base, whereas an NEG e-bell has a metal ring around the base.freebrickproductions wrote: Actual Safetran Type 2s are. NEGs are just about a dime a dozen, especially on the CSX and UP. Other than a different base on a few of them, they are also exactly alike the Safetran Type 2s, AFAIK..
- NathanFromEngland
A year or two ago, i watched this Australian Railroad Crossing video, and the Safetran Type 3 electronic bell sound got me interested into finding out more about it.
When i posted in the comments, some guy said this.
" Siemens "Wayguard Level Crossing Bell"
So i searched it and found nothing related to it. Until someone later posted in the comments stating it was the Safetran Type 3.
Although i do adore them, the only problem is that they can either die quickly or get damaged (depending if it is the 1st generation or 2nd)
https://www.google.co.uk/maps/@32.69153 ... 312!8i6656
South 28th Street, San Diego CA.
The bell appears to have broken away from the bottom part, i couldn't see any damage to the signal it was based on. So maybe it could've been damaged by weather?
https://www.google.co.uk/maps/@28.53114 ... 312!8i6656
West Gore Street, Orlando FL.
The top of the bell has completely vanished, maybe this could've been weather related too?
Safetran is now owned by Siemens, but some products are carried under the Siemens and Safetran name.
Refer to me as 'Nari' - She/They are my preferred pronouns
Thanks!freebrickproductions wrote:Pages 11-12 here:nickrink wrote:Does anyone know where I can view bells on Siemens website?
Pages 3-6 here:
YouTube Channel: https://www.youtube.com/channel/UCC-CXi ... crUJ90nU-A
