Again, the wind guard does not hold the gate up. It just keeps it from swaying too much when the wind blows. That right there is another issue with the hold clear not working right.NathanFromEngland wrote:Here is another case of gate mechanism errors.
This crossing in Plainfield Illinois, had a problem with the gate not catching the wind guard and constantly lowering. The gate mechanisms are US&S Model 95's which in my case are the worst gate mechanisms ever made.
Crossing Malfuction/Fails Sightings
Re: Crossing Malfuction/Fails Sightings
- ToledoRailfan
- TrickyMario7654
Wow! That's got to be one of the worst malfunctions I've ever seen!ToledoRailfan wrote:
Anyways, here's a bunch of idiots going around the gates (including a school bus) at the Hallam level crossing (which was malfunctioning at the time).
If you watch the video again, it looks like the entire mechanism was turned off center a bit. When it goes up it is hitting the end of the wind guard which is not allowing it to go fully upright. That would not involve the hold clear... would it? That is why I like the newer wind guards like this one.freebrickproductions wrote:Again, the wind guard does not hold the gate up. It just keeps it from swaying too much when the wind blows. That right there is another issue with the hold clear not working right.NathanFromEngland wrote:Here is another case of gate mechanism errors.
https://www.google.com/maps/@27.8391028 ... r8-Q?hl=en
Huh, it does seem to be that way. I know with the S60s, if they hit the wind-guard, then they'll just go right back down again.cabman701 wrote:If you watch the video again, it looks like the entire mechanism was turned off center a bit. When it goes up it is hitting the end of the wind guard which is not allowing it to go fully upright. That would not involve the hold clear... would it? That is why I like the newer wind guards like this one.freebrickproductions wrote:Again, the wind guard does not hold the gate up. It just keeps it from swaying too much when the wind blows. That right there is another issue with the hold clear not working right.NathanFromEngland wrote:Here is another case of gate mechanism errors.
Yikes!
- NathanFromEngland
Gates get stuck in mid-air, when CSX come out they work fine.
The crossing was replaced in 2013.
- ToledoRailfan
One of the gates here failed to get all the way up:
Looks like the gate itself was bent and the arm was all the way up.freebrickproductions wrote:One of the gates here failed to get all the way up:
