WRRS light heads with mounting elbows and mounting base
jd318mike
Ok trying to sell or finish this set of lights, does anybody have a pair of matching WRRS light heads, with mounting elbows, and a base casting so I can properly mount my flashers. The pole is almost 5", I eyeballed with with the tape measure, was just over 4.75 in dia. While this whole set up weighs a ton, it is neat looking with the cast iron cross bucks. Thanks Mike
Due to economic conditions, the light at the end of the tunnel has been removed.
Re: WRRS light heads with mounting elbows and mounting base
This set up is all original other than missing the second pair of lights and arms. I used to have one of the spring board mounted flasher relays years ago with the glass bottom. I have seen the plug in style as well. Not as nice as the adjustable type, but sometimes it could be better than nothing. Mike
