I hope they get rescued.freebrickproductions wrote:Looks like it was a restaurant of some kind. Like the signal with the Griswold lights though.LARDLOGO wrote:Odd abandoned railroad graveyard
https://goo.gl/maps/GzkUe6rDm2y
https://goo.gl/maps/7dTELjtc66w
https://goo.gl/maps/4HvbuVKfaTT2
Didn't know they used hoppers.
https://goo.gl/maps/NANA7EbdpDQ2
Active crossing:
https://www.google.com/maps/@41.5931985 ... 312!8i6656
Why are these lights separated from each other?
https://www.google.com/maps/@27.7517422 ... 6656?hl=en
For some reason, this is Brewster, Florida. But GSV picks it up as Mulberry, Florida.
Looks like it's because they were originally aimed towards traffic coming around the curve:NathanFromEngland wrote:Why are these lights separated from each other?
https://www.google.com/maps/@27.7518186 ... 1664?hl=en
Somebody must've hit the old signal here back in the day.
https://www.google.com/maps/@30.0324815 ... 312!8i6656
Your a little too far from Utah, aren't you skip?
https://www.google.com/maps/@30.0261026 ... 312!8i6656
What's this fella up to?
https://www.google.com/maps/@30.0256439 ... 312!8i6656
Hi there!
https://www.google.com/maps/@30.0126611 ... 312!8i6656
This crossing still has catseyes 2 tracks sign!
https://www.google.com/maps/@30.0134709 ... 312!8i6656
https://www.google.com/maps/@30.0133184 ... 312!8i6656
Its quite interesting to see a WABCO model 95 in Louisiana.
https://www.google.com/maps/@30.0099245 ... 328!8i1664
Its gone now.
https://www.google.com/maps/@30.0100428 ... 312!8i6656
I can't work out if this was a light for the relay case, or just a fan in which somebody has tried to block with wires.
https://www.google.com/maps/@30.009132, ... 312!8i6656
Weird bell mounting.
https://www.google.com/maps/@30.0056536 ... 312!8i6656
Active crossing.
https://www.google.com/maps/@30.0049561 ... 312!8i6656
WABCO 12X20 inch lights?
Former base for a cantilever?
https://www.google.com/maps/@30.0034234 ... 312!8i6656
Whoops!
https://www.google.com/maps/@30.0018498 ... 312!8i6656
What's this?
https://www.google.com/maps/@29.9978554 ... 312!8i6656
Hi there!
Its gone now.
Active crossing.
Whoops!
What's this?
Minus the actual catseyes.NathanFromEngland wrote: This crossing still has catseyes 2 tracks sign!
Yea, just inverted 2 tracks signs. Still cool to see though.ToledoRailfan wrote:Minus the actual catseyes.NathanFromEngland wrote: This crossing still has catseyes 2 tracks sign!
That was actually a WABCO AL-70.NathanFromEngland wrote: Its quite interesting to see a WABCO model 95 in Louisiana.
That was actually a weather-head where the power for the relay case was connected through.NathanFromEngland wrote: I can't work out if this was a light for the relay case, or just a fan in which somebody has tried to block with wires.
Of an older variety, I believe. For a long time, no-one could figure out who made those, but I suspect that they're WABCO (or at the very least US&S) as they've only been found on installs that feature WABCO equipment.NathanFromEngland wrote: WABCO 12X20 inch lights?
Just a 5 inch mast signal which has had an extension fitted onto it for some reason, though it appears that it was done to hook some power to that signal for some reason. Here's how it looked before:NathanFromEngland wrote: Former base for a cantilever?
https://www.google.com/maps/@30.0033834 ... 328!8i1664
An 8 inch Eagle Flat-back double beacon. I doubt it works though.NathanFromEngland wrote: What's this?
An 8 inch Eagle Flat-back double beacon. I doubt it works though.[/quote]NathanFromEngland wrote: What's this?
It did in 2008.
https://www.google.com/maps/@29.9977952 ... 328!8i1664
I didn't know this was getting removed.
https://www.google.com/maps/@-38.130326 ... 6656?hl=en
