You missed one in CT.Steven429 wrote:So after reading this forum, I made a map showing how many many gates are left in the U.S
https://drive.google.com/open?id=1oJbEt ... sp=sharing
There are not much left
A-frame/Wishbone gate locations
Re: A-frame/Wishbone gate locations
Where?freebrickproductions wrote:You missed one in CT.Steven429 wrote:So after reading this forum, I made a map showing how many many gates are left in the U.S
Same line as the one you've already marked, just at a different crossing.Steven429 wrote:Where?freebrickproductions wrote:You missed one in CT.Steven429 wrote:So after reading this forum, I made a map showing how many many gates are left in the U.S
Found it!freebrickproductions wrote:Same line as the one you've already marked, just at a different crossing.Steven429 wrote:Where?freebrickproductions wrote:You missed one in CT.Steven429 wrote:So after reading this forum, I made a map showing how many many gates are left in the U.S
Ohio Street, Kokomo, IN:
https://www.google.com/maps/@40.4932457 ... 312!8i6656
And this one is confirmed to be there still, as a person on YouTube filmed the crossing recently, showing that the gate arm is still there and still used!
The gate mechanism on the other side is broken though, dropping the gate when it starts to lower and then almost dropping it twice as it raises:
That broken mechanism is really alarming, seeing the speed it dropped at it lowered within less than two seconds.freebrickproductions wrote:Ohio Street, Kokomo, IN:
Refer to me as 'Nari' - She/They are my preferred pronouns
That might be why that gate light is broken.NathanFromEngland wrote:That broken mechanism is really alarming, seeing the speed it dropped at it lowered within less than two seconds.freebrickproductions wrote:Ohio Street, Kokomo, IN:
If Mr. Allan Smith stood under that he would either get his head broken or get lucky and have his head go in between the gate
So you either expect him to suffer a fractured skull or a concussion. (That's the two ways that i know of head injurys and also trauma)Steven429 wrote:That might be why that gate light is broken.NathanFromEngland wrote:That broken mechanism is really alarming, seeing the speed it dropped at it lowered within less than two seconds.freebrickproductions wrote:Ohio Street, Kokomo, IN:
Don't worry. He's already a gate on his own.Steven429 wrote: If Mr. Allan Smith stood under that he would either get his head broken or get lucky and have his head go in between the gate
Palmerston Street, Westport, New Zealand.
WABCO Gate Mechs with A-Frame Gates, that's something I've never seen!
https://www.google.com/maps/@-41.764166 ... 312!8i6656
Just down the line is this gem of a crossing.
Equipped with Griswolds and two Beautiful Black & White A-Frames!
https://www.google.com/maps/@-41.765431 ... 312!8i6656
