Tracks out of service
Re: Tracks out of service
Those are WABCO AL-70 "Triangle" gate mechs. RACO Hydraulics are more like these:
http://rxrsignals.com/Pennsylvania/Strasburg/Paradise/
Some other crossings along that line:
https://www.google.com.au/maps/@38.0969 ... 312!8i6656
https://www.google.com.au/maps/@38.0976 ... 312!8i6656
This signal has some Federal Signal 12x20s and what appears to be a US&S mechanical bell?
https://www.google.com.au/maps/@38.0975 ... 312!8i6656
Both signals use hexagonal gate-arms!
https://www.google.com.au/maps/@38.0974 ... 312!8i6656
https://www.google.com.au/maps/@38.1049 ... 312!8i6656
Another hexagonal gate-arm!
This crossing was closed before the line went dead:
https://www.google.com.au/maps/@38.1062 ... 312!8i6656
https://www.google.com.au/maps/@38.1078 ... 312!8i6656
Another Griswold EM signal here (missing its bell) with a newer WCH signal on the other side:
https://www.google.com.au/maps/@38.1098 ... 312!8i6656
It used to have an e-bell:
A pair of RACO cantilevers and more WABCO AL-70s:
https://www.google.com.au/maps/@38.1136 ... 312!8i6656
More hexagonal gate-arms!
Seeing very modern installs like this make me wonder when the line went dead:
https://www.google.com.au/maps/@38.1196 ... 312!8i6656
https://www.google.com.au/maps/@38.1224 ... 312!8i6656
These traffic lights are also out of service! Likely decommissioned when the cantilever signals were originally installed:
https://www.google.com.au/maps/@38.1221 ... 312!8i6656
https://www.google.com.au/maps/@38.1280 ... 312!8i6656
The line is still used further north.
chris96 wrote:Found an all-Griswold crossing on a disused line in Vallejo, California:
https://www.google.com.au/maps/@38.1009 ... 56!6m1!1e1
Looks like this gate is one of the hexagonal ones as well!
https://www.google.com.au/maps/@38.1009 ... 312!8i6656
What the heck happened to these visors? Almost looks like they are melted!
https://www.google.com.au/maps/@38.0941 ... 312!8i6656
chris96 wrote:Never seen this before. It appears that the gate at this crossing has been mounted in a permanent up position :Blink: :
https://www.google.com.au/maps/@38.0919 ... 56!6m1!1e1
I think your eyes might be deceiving you a bit. They used a traditional gate motor (on the cantilever mast), but put that long extension to the left so the gate itself is positioned where it won't hit the cantilever going down. The first time I saw one it got me too... I know it looks like the gate won't be able to move, but it does.
This angle is better: https://www.google.com.au/maps/@38.0918 ... 312!8i6656
brett nc railfanner
Post by brett nc railfanner »
ToledoRailfan
Post by ToledoRailfan »
That is odd, maybe they plan on having the line put back in service.
It's also possible that the line is just simply mothballed, or still "active" but not used. Similar thing happened at Monroe Street #1 here in Huntsville, even though the HMCR's Huntsville Utilities Spur isn't used anymore:
2007:
https://www.google.com/maps/@34.7226336 ... 328!8i1664
2013:
https://www.google.com/maps/@34.7225832 ... 312!8i6656
Even got blue emergency info!
2016:
https://www.google.com/maps/@34.7226348 ... 312!8i6656
freebrickproductions wrote:It's also possible that the line is just simply mothballed, or still "active" but not used. Similar thing happened at Monroe Street #1 here in Huntsville, even though the HMCR's Huntsville Utilities Spur isn't used anymore:
2007:
2013:
2016:
And the pole looks like wrought iron? That's a first for me.
Also... a bit off subject, but I just noticed this light. Do you know what it is used for? It was put in sometime between 2013 and 2016.
https://www.google.com/maps/@34.7228477 ... 312!8i6656
https://www.google.com/maps/@34.7228534 ... 312!8i6656
https://www.google.com/maps/@34.723142, ... 312!8i6656
2007:
2013:
2016:
Most of the crossbuck crossings along the HMCRs use those poles. IDK why, might've been at the request of the city of Huntsville.
cabman701 wrote:Also... a bit off subject, but I just noticed this light. Do you know what it is used for? It was put in sometime between 2013 and 2016.
It's something related to Huntsville Utilities. Not entirely sure what it's for, since it seems to be red or green regardless of anything else going on. They put them at the gates of every one of their substations here.
Why do railroads do that anyways with keeping unused crossings up-to-date? They may as well keep the tracks maintained, too...
ToledoRailfan
ZachL wrote:Why do railroads do that anyways with keeping unused crossings up-to-date? They may as well keep the tracks maintained, too...
Probably has to do with the FRA requiring all crossings that are on lines that haven't been filed for abandonment to be maintained or something similar to that.
