Google Maps Scavenger Hunt
McK&H.Aust
Post by McK&H.Aust »
ToledoRailfan
Post by ToledoRailfan »
McK&H.Aust
freebrickproductions wrote:Transport Products Corp. gate mechs!
https://www.google.com/maps/@41.6206598 ... 312!8i6656
Go up the road just a little and back in time, there was a semaphore!
https://www.google.com/maps/@41.6212035 ... 328!8i1664
ToledoRailfan
And the cool thing is that is was probably still in use! :TUP1: Otherwise they would not have replaced it with a new signal.
Oddly enough, the new signal is a Searchlight:
https://www.google.com/maps/@41.6212021 ... 312!8i6656
Seeing the "App" plate tells me that this is a fixed Approach signal (also called a distant signal).
Brings up a good question... if the town does really flood that bad, you would think it would destroy the signals themselves... along with the track wiring and all that. I guess the equipment in the relay box is the most expensive part?
Just have to wonder if the lights have been underwater at some point and survived.
ToledoRailfan
The "before signals" (could not think of a different term) are old incandescent signals while the signals at the intersection are modern L.E.D signals. There is also a blackout signal here which is something that I've not seen on this kind of setup before.
https://www.google.com/maps/@42.0798992 ... 6656?hl=en
https://www.google.com/maps/@42.0798987 ... 6656?hl=en
Notice how far away the crossing is from the intersection! I'm surprised that they went with this setup despite the crossing being significantly far from the crossing. https://www.google.com/maps/@42.0798987 ... 6656?hl=en
Kind of an odd setup. https://www.google.com/maps/@42.0246378 ... 6656?hl=en
I thought that was a real deer at first. :oops: https://www.google.com/maps/@42.0246378 ... 6656?hl=en
This is another odd setup, it does not seem very safe. https://www.google.com/maps/@41.7259395 ... 6656?hl=en
What is this thing? https://www.google.com/maps/@41.8773706 ... 1664?hl=en
Bell only crossing. https://www.google.com/maps/@41.7969667 ... 6656?hl=en
Classic signals with some 8'' G.R.S Lex-c lights! https://www.google.com/maps/@41.7881303 ... 6656?hl=en https://www.google.com/maps/@41.788379, ... 6656?hl=en
This crossing has pedestrian gates for the sidewalk, something that I have not seen in Michigan. I think they did this here because of Amtrak's high speed rail through here. https://www.google.com/maps/@41.801019, ... 6656?hl=en https://www.google.com/maps/@41.8007232 ... 6656?hl=en
Here is a cool signal for a side street. https://www.google.com/maps/@34.268532, ... 6656?hl=en
ToledoRailfan wrote:This is another odd setup, it does not seem very safe. https://www.google.com/maps/@41.7259395 ... 6656?hl=en
Not necessarily. It's a spur line, which means it doesn't receive much usage, hence the crossbucks only.
