Google Maps Scavenger Hunt
Crossing deactivating after a train has passed:
https://www.google.com/maps/@32.9473227 ... 312!8i6656
https://www.google.com/maps/@32.9474372 ... 312!8i6656
Proof that they DO actually move signals sometimes... even older ones.
https://www.google.com/maps/@42.282227, ... 6?hl=en-US
Oddly enough, this one appears to have been moved only a couple of feet. The gate now comes down over the 2nd track:
https://www.google.com/maps/@42.279728, ... 4?hl=en-US
https://www.google.com/maps/@42.2797644 ... 6?hl=en-US
8 signals in this view, plus a tornado siren:
https://www.google.com/maps/@42.2592504 ... 6?hl=en-US
Another 8 signal crossing, this time active with a train. This are the same tracks that run through Wyndotte:
https://www.google.com/maps/@42.2369797 ... 6?hl=en-US
Active crossing:
https://www.google.com/maps/@42.2895683 ... 6?hl=en-US
This same crossing 2 years later now has gates... and traffic signals? https://www.google.com/maps/@42.2895412 ... 6?hl=en-US
Active crossing:
I thought these guys were cool! I haven't seen too many signals (other than cantilevers) anymore where the gates are on a separate mast from the signals:
https://www.google.com/maps/place/Bedfo ... 49!6m1!1e1
https://www.google.com/maps/@38.7235789 ... 56!6m1!1e1
https://www.google.com/maps/@38.6721493 ... 56!6m1!1e1
Unusual setup:
https://www.google.com/maps/@38.7247261 ... 56!6m1!1e1
(oh boy, I could go on...)
Unusual setup:
I do like those types of crossing also. I would have to assume for most of them they were one time gateless, and this was a cheaper way to upgrade them.busman_49 wrote:I thought these guys were cool! I haven't seen too many signals (other than cantilevers) anymore where the gates are on a separate mast from the signals:
IDK, I think that was just a way some railroads did their gates back in the days of wooden gates. I know installs like that are common on ex-L&N lines. Probably saved a bit of money as well, as all you'd need to do is buy a bunch of 4 inch masts for the lights (and sometimes bells) and 5 inch masts for the gate mechanisms, which would be used at both gated mast signal installs and gated cantilever signal installs.cabman701 wrote:I do like those types of crossing also. I would have to assume for most of them they were one time gateless, and this was a cheaper way to upgrade them.busman_49 wrote:I thought these guys were cool! I haven't seen too many signals (other than cantilevers) anymore where the gates are on a separate mast from the signals:
RACO gate mechanism on that signal as well!cabman701 wrote: Oddly enough, this one appears to have been moved only a couple of feet. The gate now comes down over the 2nd track:
https://www.google.com/maps/@42.2795692 ... 6?hl=en-US
- TrickyMario7654
I think those sort of set-ups were used in Melbourne when the crossing was located at an angle.freebrickproductions wrote:IDK, I think that was just a way some railroads did their gates back in the days of wooden gates. I know installs like that are common on ex-L&N lines. Probably saved a bit of money as well, as all you'd need to do is buy a bunch of 4 inch masts for the lights (and sometimes bells) and 5 inch masts for the gate mechanisms, which would be used at both gated mast signal installs and gated cantilever signal installs.
Looks like a Whelen sirencabman701 wrote:8 signals in this view, plus a tornado siren:
https://www.google.com/maps/@42.2599692 ... 6?hl=en-US
- TrickyMario7654
Found this passive crossing in Hoquiam, Washington with a yellow Yield sign.
https://www.google.com.au/maps/@46.9679 ... 312!8i6656
Looks like it was custom made for the crossingTrickyMario7654 wrote:Found this passive crossing in Hoquiam, Washington with a yellow Yield sign.
Still a neat find though. Yellow yield signs are hard to find since the standard was changed to the red and white ones in the 1970s, IIRC.LARDLOGO wrote:Looks like it was custom made for the crossingTrickyMario7654 wrote:Found this passive crossing in Hoquiam, Washington with a yellow Yield sign.
