I wonder why the reused older equipment for the new signals at Granville? In hindsight, it would have been better to just keep the old signals in operation rather than installing new ones that would only last about six years.McK&H.Aust wrote:After filming the crossing at Parramatta Rd, Granville, I've discovered some interesting things https://www.google.com.au/maps/@-33.832 ... 312!8i6656
The current gated signals were installed in 2013 when they replaced the Type B gate mechs which dated back to 1961. These new gate mechs were actually recycled as they are painted white and have the old WCH logo https://www.google.com.au/maps/@-33.832 ... 312!8i6656 I suspect the gate mechs came from this crossing at Birrong which was closed not long after this GSV image from 2009 https://www.google.com.au/maps/@-33.887 ... 312!8i6656 The signals here were short lived as they were only installed around 2001, so the gate mechs would still have been in good condition. The only other crossing they could have came from is Casula which was closed around the same time, but I doubt those mechs were recycled as they are much older, having been installed in the early 1990's https://www.google.com.au/maps/@-33.950 ... 312!8i6656
The lights and their brackets on the new gated signals are also recycled, with both having Alstom branding https://www.google.com.au/maps/@-33.832 ... 312!8i6656
The WCH base on this gated signal is dated June 2005, so I guess it was also recycled, but not sure where from https://www.google.com.au/maps/@-33.832 ... 312!8i6656
Sadly the demise of this interesting crossing has moved one step closer with the NSW government recently signing contracts for the construction of the Parramatta Light Rail Project. http://data.parramattalightrail.nsw.gov ... ZtR3UM.DXY
Construction is due to begin this year which will see the section of track between Clyde and Camellia closed and the crossing removed. The remainder of the line between Camellia and Carlingford will be converted to light rail. The crossing at Parramatta Rd is the last in NSW to be manually operated from it's own adjacent signal box, it doesn't appear to be heritage listed so could quite possibly be demolished https://www.google.com.au/maps/@-33.832 ... 312!8i6656
It got me to thinking what other manually operated crossings remain in NSW and I could only think of two. They are at Adamstown https://www.google.com.au/maps/@-32.933 ... 312!8i6656 and Hamilton https://www.google.com.au/maps/@-32.918 ... 312!8i6656 although both crossings are remotely controlled from Broadmeadow via CCTV cameras.
Another surviving crossing that was manually operated is at Blackshaw Rd, Goulburn. It was converted to automatic operation some time around 2008 after Goulburn Signal Box was closed https://www.google.com.au/maps/@-34.753 ... 312!8i6656
You can still see the CCTV cameras which were linked to Goulburn Signal Box https://www.google.com.au/maps/@-34.753 ... 312!8i6656 https://www.google.com.au/maps/@-34.753 ... 312!8i6656
Going back to 2007 the crossing had full length gates while it was manually operated https://www.google.com.au/maps/@-34.753 ... 328!8i1664
They actually weren't the original signals. Found my old photographs from May 1986 showing Type B gate mechs. The lights are possibly Westinghouse and the bells look like older model WCH or FS.
https://drive.google.com/open?id=1RwTsU ... Ut7TzrkDFi
https://drive.google.com/open?id=1lF_xr ... cXCQlF4jiX
https://drive.google.com/open?id=1RukjD ... CA-ivqsQXr
I didn’t know that Goulburn perviously had older signals, I always thought prior to the current signals being installed it had manually operated gates. Now that I think about it, I wonder if these supposed ‘older’ signals are the current ones, just with the original gate mechs and lights replaced sometime in the 1990’s?
