Some flat sounding bells
Re: Some flat sounding bells
I almost wonder if some of these "cowbell" sounding bells are due to the gong not having been rotated, and so the hammer struck it until it cracked...
- NathanFromEngland
Here's a extremely flat WCH E-Bell.
Fun Fact! I watched this video back in 2007 or 2008! Back then i was only 5-6!
A few other videos of the Type 1s at this crossing messing up, probably due to fog or humidity:NathanFromEngland wrote:This General Signals Type 1 is having a hard time sounding, while the other GS type 1 seems to be working fine.
- ToledoRailfan
The bell sounded normal when I was there two and a half years ago.freebrickproductions wrote:A few other videos of the Type 1s at this crossing messing up, probably due to fog or humidity:NathanFromEngland wrote:This General Signals Type 1 is having a hard time sounding, while the other GS type 1 seems to be working fine.
I think it has to do with the humidity in the air at the time. Newer videos of the crossing show the bells working fine again:ToledoRailfan wrote:The bell sounded normal when I was there two and a half years ago.freebrickproductions wrote:A few other videos of the Type 1s at this crossing messing up, probably due to fog or humidity:NathanFromEngland wrote:This General Signals Type 1 is having a hard time sounding, while the other GS type 1 seems to be working fine.
Also, I've noticed that GS Type 1s that sound like this only ever seem to crop up in Michigan. I kind of wonder why....
- TrickyMario7654
Probably the same reason why adjusted Type 1's die often in Melbourne...freebrickproductions wrote:Also, I've noticed that GS Type 1s that sound like this only ever seem to crop up in Michigan. I kind of wonder why....
I personally think that in the case of the Type 1s in Michigan, it might have something to do with the climate and how the bells there are required to ring while the gates are down.TrickyMario7654 wrote:Probably the same reason why adjusted Type 1's die often in Melbourne...freebrickproductions wrote:Also, I've noticed that GS Type 1s that sound like this only ever seem to crop up in Michigan. I kind of wonder why....
Also, this Hybrid bell at this crossing sounds a bit flat:
One of the GS Type 2s at this crossing had a bit of trouble starting:
- NathanFromEngland
This Safetran Type 2 sounds like something being banged with a hammer.
Turn your volume up!
