What makes you say that?ZachL wrote:That's not even the newest way CSX installs signals, eitherNathanFromEngland wrote:New CSX installation...In front of crossbucks
https://www.google.com/maps/@36.5522846 ... authuser=0
Google Maps Scavenger Hunt
- NathanFromEngland
1) they use WCH light heads now instead of using Safetran light headsNathanFromEngland wrote:What makes you say that?ZachL wrote:That's not even the newest way CSX installs signals, eitherNathanFromEngland wrote:New CSX installation...In front of crossbucks
2) they use NEG e-bells now instead of Safetran Type-3s
3) bells are now mounted at half-mast instead of on top
https://www.google.com/maps/@27.96679,- ... 312!8i6656
- NathanFromEngland
I am aware of that. However in some rare cases you may see Safetran Type 3's mounted half mast. I do have a post i believe somewhere in the thread that has a link to them.ZachL wrote:1) they use WCH light heads now instead of using Safetran light headsNathanFromEngland wrote:What makes you say that?ZachL wrote:That's not even the newest way CSX installs signals, eitherNathanFromEngland wrote:New CSX installation...In front of crossbucks
Active crossing in Holt, Florida.
https://www.google.co.uk/maps/@30.70482 ... 328!8i1664
If you're aware of that, then why did you ask "how so" when I pointed out that your example is not the newest way CSX does installs?NathanFromEngland wrote:I am aware of that. However in some rare cases you may see Safetran Type 3's mounted half mast. I do have a post i believe somewhere in the thread that has a link to them.ZachL wrote:1) they use WCH light heads now instead of using Safetran light headsNathanFromEngland wrote:What makes you say that?ZachL wrote:That's not even the newest way CSX installs signals, eitherNathanFromEngland wrote:New CSX installation...In front of crossbucks
It was also already a couple of years old by the time street view went through there.ZachL wrote:If you're aware of that, then why did you ask "how so" when I pointed out that your example is not the newest way CSX does installs?NathanFromEngland wrote:I am aware of that. However in some rare cases you may see Safetran Type 3's mounted half mast. I do have a post i believe somewhere in the thread that has a link to them.ZachL wrote:1) they use WCH light heads now instead of using Safetran light headsNathanFromEngland wrote:What makes you say that?ZachL wrote:That's not even the newest way CSX installs signals, eitherNathanFromEngland wrote:New CSX installation...In front of crossbucks
- dan the ca railfan
two crossings active at the same time!
https://www.google.com/maps/@41.5555425 ... 312!8i6656
same town same train too!
https://www.google.com/maps/@41.5554716 ... 312!8i6656
- NathanFromEngland
EBA E-bells on a crossing with incandescent lights in Saltsjöbaden, Stockholm County
https://www.google.com/maps/@59.2885165 ... 6656?hl=en
