Google Maps Scavenger Hunt
NathanFromEngland wrote:
ZachL wrote:
freebrickproductions wrote:
Ethan the Railfanner wrote:Active Crossing near Trezevant, TN:
https://www.google.com/maps/@36.0235427 ... 312!8i6656
Noticed that the street blade next to the crossing claims that US 79 is "TN 79" (the road is also TN 76, but that means the street blade is still wrong).
i never knew those things were called street blades...
Probably obvious that they have that name due to them shaped like razor blades (ouch)
Well, any street sign is like that.
LARDLOGO
Post by LARDLOGO »
Older technology?
https://goo.gl/maps/5MjUENu38hR2
Traffic lights are installed onto the cantilever.
https://goo.gl/maps/dRmYRQA4iru
On the other side, there are two bells; one on the cantilever and one on the mast.
https://goo.gl/maps/JsFT9mHtx7T2
Third signal.
https://goo.gl/maps/iJvKgDSSrX12
Another side signal at the next crossing.
https://goo.gl/maps/o7p4nk4hSuS2
Fence dividing both tracks.
https://goo.gl/maps/J18DVs7FAX52
Interesting.
https://goo.gl/maps/EexrJKNQx7A2
https://goo.gl/maps/US53gqLDLe72
Approaching Train.
https://goo.gl/maps/XWE9mfwhmK62
Cantilevers are on the same side of the road.
https://goo.gl/maps/SJa5a34cAvD2
Another train.
https://goo.gl/maps/6GcTY1ssoWx
Another example of traffic lights installed on the cantilever. The cantilever lights are on a stick.
https://goo.gl/maps/3xMkHDNjahJ2
No crossbucks, only stop signs.
https://goo.gl/maps/eZanhxckWtv
Out of service track removed, except for at this crossing.
https://goo.gl/maps/F7xmBFdxZBs
https://goo.gl/maps/a69y9mo5PfK2
Kind of like the old "STOP WHEN SWINGING" signs.
https://goo.gl/maps/opqDQPx5ySQ2
Small crossbucks for pedestrian crossing. Also note "CROSSING RAILROAD"
https://goo.gl/maps/5oGcFf18qxJ2
https://goo.gl/maps/KRZYVE5Skik
No crossbuck.
https://goo.gl/maps/owaFoqVgeAk
Odd crossbuck and vandalized stop sign.
https://goo.gl/maps/SUgsKBrEAW72
Nearby sign was also vandalized.
https://goo.gl/maps/93CvdyJWwC82
On the other side, smaller stop sign and vandalized crossbuck.
https://goo.gl/maps/1Dg5AF5XigA2
Only one crossbuck here.
https://goo.gl/maps/HfLgkFADMj32
Crossbucks are farther away from the tracks than normal.
https://goo.gl/maps/6yCqj92o76x
https://goo.gl/maps/dWzCtqqdTVv
LARDLOGO
Post by LARDLOGO »
LARDLOGO wrote:Large relay case.
https://goo.gl/maps/7hGQyFajTe32
Those are called relay bungalows.
The LIRR likes to use masts that tall for crossings with long gate-arms, it seems.
MapsSurfer
Post by MapsSurfer »
Here are some Dutch-Made Crossing Signals in Ghana.
I believe these were manufactured by the Dutch Company "Alkmaar". Although I'm not to sure about that.
The majority of Signalized Crossings can be found in the capitol city of Accra, there are an extreme few outside of the capitol.
This first Crossing has no Signs or Signals, but since there is a Guard's Shanty, this leads me to believe that they once had some Signalization here at some point.
https://www.google.com/maps/@5.6511362, ... 312!8i6656
This next Crossing has one pair Signals, but I highly doubt that they are operational. The Guard's Shanty can be seen behind the red umbrella.
https://www.google.com/maps/@5.6472759, ... 312!8i6656
Another completely Unguarded Crossing. This one having a flimsly-looking Metal Shanty.
https://www.google.com/maps/@5.6020219, ... 312!8i6656
However, there is a suspicious looking peg on the side of the road. Could this have been part of a long-gone Signal or Gate Mechanism?
Though I might just be looking too much into this!
Now we're talkin'! Here is a set of proper (albeit unusable) Crossing Signals. Since this is a main road, there may still be some sort of warning available.
Possibly from a bell or siren from one of those Crossing Shanty's on each side of the Avenue.
https://www.google.com/maps/@5.6066774, ... 312!8i6656
Here is rather depressed-looking set of Flashers. These also look to be out-of-use, though there is one Manual Gate on the other side of the Crossing.
So at least there's some sort of protection.
https://www.google.com/maps/@5.6112776, ... 312!8i6656
Another Unguarded Crossing, this one with Red/White Crash Barriers and a vacant Shanty.
https://www.google.com/maps/@5.6196716, ... 312!8i6656
Unguarded Crossings are the norm in Africa if you haven't caught on. Interestingly you can clearly see some French-Style Block Signals at this Crossing.
https://www.google.com/maps/@5.6197162, ... 312!8i6656
Another pair of unusable Crossing Signals. I've noticed that all of the Crossings in Accra are missing there Bells.
Maybe they never installed Crossings with bells, that or they're placed within the Guard Shanties next to the Signals.
https://www.google.com/maps/@5.6197119, ... 312!8i6656
This set of Crossing Signals are seriously beat up, they've most likely have been vandalized at some point.
https://www.google.com/maps/@5.6116099, ... 312!8i6656
Unguarded Crossing with an absolutely stunning view of the Atlantic.
Mind-you this is an active Railway, so imagined Railfanning while being on this beautiful beach!
https://www.google.com/maps/@5.6140817, ... 312!8i6656
That about does it for the Crossings in the Accra area. There are some new Italian-Style Crossing Signals around the Industrial area, but all of those are outside the range of Google Street View. Now we move on to the other active Railway in Ghana, this one is a mining Railway west of the Capitol.
This is in the Port City of Takoradi, near the Railway Terminal. As you can see, this isn't the most sanitary places in the city!
https://www.google.com/maps/@4.8887246, ... 312!8i6656
"Active" Crossing just north of Takoradi.
https://www.google.com/maps/@4.9069529, ... 312!8i6656
Here's an interesting location, the signal is obviously out-of-service, but unlike what I pointed out before this crossing DOES have a Bell.
It's one of those Classic Dutch Bells which themselves are based off WRRS mini-bells.
https://www.google.com/maps/@4.9217138, ... 312!8i6656
There are surely more ineresting Crossings to be found in Ghana, but these are all the crossings of note captured on Google Street View.
To rap this up I'll share with you a video taken aboard a train through Accra. In the video several Crossings that are not shone above can be seen, some with there Wooden Gates still intact! You can also some bells of unknown make ringing at several crossings as well. Enjoy!
NathanFromEngland
Post by NathanFromEngland »
One of the most oddest crossings i've ever seen.
https://www.google.com/maps/@-33.510118 ... 312!8i6656
This crossing has unusually large counterweights for US&S Model 95's.
https://www.google.com/maps/@-33.536019 ... 312!8i6656
WCH Mechanical Bell and Safetran lights on an ungated crossing which replaced a flagman signal.
https://www.google.com/maps/@-33.568520 ... 312!8i6656
Steven429
Post by Steven429 »
NathanFromEngland wrote:One of the most oddest crossings i've ever seen.
I wonder if the teardrop and/or wig wag still work or are they disconnected?
NathanFromEngland
Active crossing in Southport, England.
https://www.google.com/maps/@53.6414274 ... 312!8i6656
They're probably disconnected.
