Tracks out of service
Re: Tracks out of service
cabman701 wrote:Remnants of a searchlight signal it looks like: https://www.google.com/maps/@41.5626151 ... 6656?hl=en
Oh wow, that's pretty cool! I hope it stays around for many more years to come. :TUP2:
Looked up the DOT number on the cantilever in the first link (729758H) and found out the line had been owned by Norfolk Southern but the crossing was closed back in 1988! However, the crossing was still technically open, as the Caldwell County Railroad apparently owns the line as they are being leased it from the county after the county bought in from Norfolk Southern in 1994, but the section through Lenoir, NC was officially abandoned in 2007. Also, interestingly enough, a railroad called the Carolina and Northwestern Railroad operated the line from 1990 to 1994. I have no idea if any operations along the line were done between 1988 and 1990.
Looks like this is the farthest north the operations now go:
https://www.google.com/maps/@35.8715196 ... 312!8i6656
Also, the first still-used crossing I came to was an almost pure 1980s NS install with a Safetran mechanical bell:
https://www.google.com/maps/@35.859244, ... 312!8i6656
And then the next signalized crossing was even older, with a mechanical bell as well:
https://www.google.com/maps/@35.8457526 ... 312!8i6656
Quite a change from the signals on the abandoned section.
EDIT: Just found one with an e-bell, and traffic signal sections for the lights:
https://www.google.com/maps/@35.828441, ... 312!8i6656
freebrickproductions wrote:EDIT: Just found one with an e-bell, and traffic signal sections for the lights:
Crazy how there are concrete ties for about 50 feet on either side of that crossing, then it goes back to fairly dilapidated track.
LARDLOGO
Post by LARDLOGO »
On the old Bakersfield to Arvin Branch where the line is no longer used..... were these updates necessary?
Comanche Road
http://www.rxrsignals.com/California/A- ... /Comanche/
Safetran Type 2 E-Bells?
https://www.google.com/maps/@35.2530525 ... 56!6m1!1e1
https://www.google.com/maps/@35.2528079 ... 56!6m1!1e1
Myrtle Road.... not technically closed but 12X24 lights and E-Bells were added.
http://www.rxrsignals.com/California/I-M/Lamont/Myrtle/
https://www.google.com/maps/@35.2524479 ... 56!6m1!1e1
Some old Amtrak boxcars that were on the line for storage. They're no longer there and I'm assuming that this was the last train to use this part of the line.
https://goo.gl/maps/CZVy3RZJMYH2
Bonus, that looks like a fun staircase
https://www.google.com/maps/@35.2526661 ... 56!6m1!1e1
Sadly, crossings that receive no traffic whatsoever but are still "open" are prone to signal upgrades. It's common here with CSX. :Roll:
ZachL wrote:Sadly, crossings that receive no traffic whatsoever but are still "open" are prone to signal upgrades. It's common here with CSX. :Roll:
Sometimes, crossings don't even have to be open to get new equipment!
TrickyMario7654
Post by TrickyMario7654 »
Like this one...
Like this one...
However, that crossing is now active. If you saw the description, it said that the road was being relocated to where the signals are now. More often than not, signals are installed before road projects to prevent as little disruption in railroad activity as possible.
ToledoRailfan
Post by ToledoRailfan »
Like this one...
I think by open he met on an active line.
