Nathan/Airchime K-series horns
Posted: Sat Mar 14, 2009 11:35 am
I read about the K-series horns, and I was surprised to learn they were originally made for Canada! I'm going to explain the details of this, and the stats on each model below.
First off, the third character in each model name, either an L or H, doesn't mean anything about the sound of the horn.
It indicates which style of manifold the bells are mounted on. For that reason, I've replaced the L or H with an M.
Secondly, there are 9 different bells used in the K series horns; note that the 1 & 5, & the 1L & 4 produce the same note, but at different frequencies:
Canadian-tuned models:
These ones sound a D minor chord as mandated by the Canadian government.
K5M:
1, 2 3, 4, 5.
Used mainly by CSX & BC Rail regional. Rare even in other parts of Canada.
A couple of Amtrak locomotives have been found to use the K5L, however.
Sound
K3M:
1, 2, 3.
Used on older Canadian National & Canadian Pacific locomotives, and on VIA Rail Canada.
A total of 164 BNSF Dash-9 44CWs, numbered 960-1123 have this horn.
Sound
K5ML:
1L, 1, 2, 3, 4.
Very common in both America & Canada due to GE's extensive use of it on new locomotives.
I DON'T understand why they are mounded backwards, however.
Sound
American-tuned:
The first 2 sound a B major chord, the last one sounds a dischord.
K5MA:
1, 2, 3A, 4A, 5.
A classic with passenger carriers.
Sound
K3MA:
1, 2, 4A.
A classic with pre-2004 locomotives.
Sound
K5MLA:
1L, 1, 2, 3A, 4A.
Currently used on new EMD locomotives.
Sound
*EDIT*: Added links to sound samples, and made a change to the wording of the designations.
- 1, which sounds a note in D#
- 1L, which sounds a note in C at
- 2, which sounds a note in F#
- 3, which sounds a note in A#
- 3A, which sound a note in G#
- 3L, which sound a note in A
- 4, which sounds a note in C at
- 4A, which sounds a note in B
- 5, which sounds a note in D#
K5M:
1, 2 3, 4, 5.
Sound
K3M:
1, 2, 3.
Sound
K5ML:
1L, 1, 2, 3, 4.
Sound
American-tuned:
K5MA:
1, 2, 3A, 4A, 5.
Sound
K3MA:
1, 2, 4A.
Sound
K5MLA:
1L, 1, 2, 3A, 4A.
Sound
