Upgrade with careless problems
Posted: Sat Jun 23, 2012 9:59 pm
by Evansville64
Is there somthing wrong with the flasher EOR relay? Along with the crappy LEds the entire signal is like 10 feet from the roadway! The gate is also too short. [YouTube ]
www.youtube.com/watch?v=zontfq92Vcc [/YouTube]
Re: Upgrade with careless problems
Posted: Wed Jun 27, 2012 9:07 pm
by TrainmanKight
Evansville64 wrote:Is there somthing wrong with the flasher EOR relay? Along with the crappy LEds the entire signal is like 10 feet from the roadway! The gate is also too short. [YouTube ]
Nothing wrong with the EOR(Flasher Relay) its the frame rate on the camera that messes up, look at the gate lights they work fine.
Gate is not spouse to cove the whole road, and I'd prefer a signal to be off of the roadway, less likely to get hit then.
Also I think there going to do some road expansion there, All in all the new signals are much nicer then the old signals.
If you counted the warning time it don't meet FRA minimum warning time of 20 seconds! That's considered an activation FAILURE!
