Green Street, Athens, AL
Signal on the left: 1.5 pairs of Modern Industries 12x24 inch lights with WCH 2nd Gen LEDs and one Safetran 12x24 inch light with a WCH 2nd Gen LED in it.
Signal on the right: 2 pairs of Modern Industries 12x24 inch lights with WCH 2nd Gen LEDs and a Safetran Type 2 electronic bell.
http://www.rxrsignals.net/Alabama/Athens/Green/
Re: Green Street, Athens, AL
Signal on the left: 1.5 pairs of Modern Industries 12x24 inch lights with WCH 2nd Generation LEDs and 1 Safetran 12x24 inch light with a WCH 2nd Generation LED.
Signal on the right: 2 pairs of Modern Industries 12x24 inch lights with WCH 2nd Generation LEDs, and an NEG electronic bell.
Pretty much immediately after the northbound train passed, the signal at the north end of Athens siding turned green for a southbound train to come through. As such, I decided to head one block south and record this crossing since I hadn't recorded it in about 4 years or so. After a little while of waiting, I heard a horn to my north, and this southbound intermodal train came rolling through with easily the best lash-up that I saw all day: a YN2 AC44CW leading a YN3b Dash-8 and a YN3b SD40-3! Interestingly enough, the SD40-3 is the same one that I saw as the power for the Notasulga-based local on the CSX WofA Sub last year.
In the four years between my last video of this crossing and my current one, nothing much has changed to this nice pair of older L&N signals. However, interestingly enough, it appears that CSX has replaced the Safetran Type 2 that had been here with an NEG e-bell, despite the fact that the Safetran Type 2 was one of the later ones. I'm honestly not sure if the Safetran Type 2 died, or they just chose to replace it here so they could re-use it at Moyers Road in Tanner, for some reason.
http://www.rxrsignals.com/Alabama/A-F/Athens/Green/
No major changes here as of 9-3-21:
And a daytime video of the eastern side of this crossing on 10-17-21:
No changes here in the two years since I last filmed this crossing:
No changes here as of 6-16-25 either:
Still the same as of 1-16-26 as well:
