US&S FN16a parts needed and a mount for my indicator lense
Posted: Mon Jun 22, 2009 5:19 pm
by jd318mike
I am hunting for the following parts for a US&S FN16a flasher relay. I need the two main coils, the top plate with the RF Choke coil that hangs in the middle and a stack of proper washers to set the flash rate. I am also hunting for the mount, I believe it was made by US&S, uses a thick clear glass fresnel lense that I have one of, mounted usualy upside down or the open end up. Around here they are mounted to a U shaped piece of conduit off the side or back of the relay case, it has 4 long machine screws with a cross plate to retain the lense to the mount. I wouldnt even mind having a whole 2 door relay case, i could put my crossing relays and power supply, as well as a few other items in there. Thanks Mike T
