Aetna Hill Road, Whiteside, TN
Posted: Sat Feb 08, 2025 6:20 am
*originally recorded on 1-24-25*
Signal on the left: 2 pairs of WCH 12x24 inch lights with Leotek EV Series LEDs, 1 pair of Safetran 12x24 inch lights with WCH 2nd Generation LEDs, an NEG electronic bell, a Safetran-branded Siemens gate mechanism, and NEG LED gate lights.
Signal on the right 2 pairs of WCH 12x24 inch lights with Leotek EV Series LEDs, an NEG electronic bell, a Safetran-branded Siemens gate mechanism, dead NEG LED gate lights, and a RECO LED gate light.
After catching 12T at Wauhatchie Pike #3, it was held back from Wauhatchie Pike #2 for a bit while a 73Z met (I believe) 288. However, as 73Z was heading for the Chattanooga Sub, I decided to head west over to this crossing in Whiteside, as it was the last crossing on the Chatt Sub I needed to film between Chattanooga and Cowan. After a bit of waiting, I was able to catch my fifth train of the day here: NS 73Z with a pair of BNSF SD70ACes pulling on the head-end, and an H2 BNSF AC44CW working as the train's DPU.
This crossing is a decent one, though it definitely ain't the most interesting one I recorded, especially on this day. The signals here are a pretty modern CSX install from about 2017-2018, most likely replacing a pair of crossbucks. It appears they haven't changed too much from when they were installed, with really only the closer signal having its tip gate light replaced with a RECO LED at some point. Strangely, neither of the two remaining NEG LED gate lights on the closer signal work anymore, I suspect they're both just dead rather than it being a fault with the wiring given the fact that the RECO LED on the same arm still works. I suspect the Safetran 12x24s on the far signal here were reused from somewhere else, though I ain't sure where they would've come from. The bell on that signal is also mounted to the bracket for the side lights, rather than the main lights like normal, which looks a bit weird. With this video, however, I have now recorded every crossing on the CSX Chattanooga Subdivision between Chattanooga and Cowan, TN!
I will say, this crossing has a great view looking to the south across the valley I-24 runs through here. Unfortunately, not only did the sun prevent me from setting-up on that side on this day, the steepness of the hill and the grade of the crossing itself basically block-out that view entirely when set-up to record the crossing on that side of it. As expected, the road leading up to this crossing is a somewhat steep, one-lane road that makes a sharp curve right next to the crossing to cross the CSX Chattanooga Sub. I will admit it was a bit unnerving trying to cross the tracks here, as having to make something of a "leap of faith", blindly steering in what I hoped was the correct direction of the road when I was heading back towards the highway through Whiteside as I was leaving here, due to my car's hood completely obscuring where I was supposed to be going. Thankfully, I was able to make it to my next spot down in Georgia without issue.
https://www.rxrsignals.com/Tennessee/R- ... etna_Hill/
Re: Aetna Hill Road, Whiteside, TN
Posted: Sun Sep 06, 2026 10:41 am
*originally recorded on 5-9-26*
Signal on the left: 2 pairs of WCH 12x24 inch lights with Leotek EV Series LEDs, a dead NEG electronic bell, a Safetran-branded Siemens gate mechanism, NEG LED gate lights, and a RECO LED gate light.
Signal on the right: 2 pairs of WCH 12x24 inch lights with Leotek EV Series LEDs, 1 pair of Safetran 12x24 inch lights with WCH 2nd Generation LEDs, the base of an NEG electronic bell, a Safetran-branded Siemens gate mechanism, and NEG LED gate lights.
I'd heard a few weeks prior that, due to the weather delaying completion of its repaint, the TVRM wasn't going to be able to have the Southern 4501 pull the inaugural Summerville Steam Special for the year, and, as the Southern 630 is also down for its Federally-mandated 1,472 (operating) day rebuild, they were subbing-in SOU 5000 to pull the train. Not wanting to miss the chance to make such a nice long chase of that unit, I got on up bright and early to head for Chattanooga on the morning of National Train Day. As I was passing through Stevenson on US 72 on my way to Chatt, I saw this M585 heading down the CSX Chattanooga Subdivision with a heritage unit trailing! As such, I decided to chase it over to this crossing, hoping there'd be good lighting on this side of it, as I'd been wanting to shoot this angle for a while. Unfortunately, this side was pretty backlit, but I still set-up here and waited. After a little while of waiting, I was able to catch my first train of the day: CSX M585 with a CM44AC leading CSX 1869, the C&O heritage unit!
As you can see, since I was last here, the closer signal somehow lost its NEG e-bell! The base of it is still there with a couple of wires sticking-out of it, which makes me think that it must've gotten knocked-off of the signal somewhat recently, possibly during some track work as it appears that CSX recently replaced the ties under the crossing's grade here. Not helping is the fact that the far signal's bell is dead, leaving this crossing completely silent as a result. I imagine that CSX will replace both bells here before too long though, and they also fixed (or replaced) the two dead gate lights on the far signal.
