1st Street, Hopkinsville, KY
Posted: Tue Dec 30, 2025 7:29 am
*originally recorded on 12-6-25*
Signal on the left: 1 pair of WCH 12x24 inch lights with WCH 2nd Generation LEDs, 3 pairs of Modern Industries 12x24 inch lights with WCH 2nd Generation LEDs, an NEG electronic bell, a dead Safetran Type 3 electronic bell, an Invensys Rail gate mechanism, and RECO LED gate lights.
Signal on the right: 1 pair of WCH 12x24 inch lights with WCH 2nd Generation LEDs, 3 pairs of Modern Industries 12x24 inch lights with WCH 2nd Generation LEDs, an NEG electronic bell, an Invensys Rail gate mechanism, RECO LED gate lights, and an NEG LED gate light.
On December 6th, I met-up with CentralALSirens at my house and we hit the road to try and catch the monthly siren test in Paducah, KY. Unfortunately, we didn't realize they weren't testing this month, so that was a bit of a bust. Either way, on the way up, we saw there was enough time prior to when the test would be happening that we decided to stop in Hopkinsville on the way and see if we could try to catch a train before the test. Thankfully, after a little while of waiting, we were able to catch our first train of the day: CSX M513 with an AC44CW leading an SD70MAC for power.
This crossing is a pretty neat one, even if it ain't the most interesting set-up out there. The cantilevers here were originally installed by CSX back in the mid-1990s, with the cantilevers themselves having been made in 1993 per the dates on the little data panels on their masts, and were originally gateless. Then, in the mid-2000s, CSX replaced the bell here with a Safetran Type 3 e-bell. Finally, sometime between 2013 and (presumably) about 2014 or so, CSX upgraded this crossing to gates. Interestingly, rather than replacing the existing cantilevers entirely, CSX chose to just install a pair of brand new gate masts in front of the existing gateless cantilevers, and hooking said cantilevers into the new relay case. In the process, CSX removed the front pairs of mast lights from both cantilevers and upgraded the remaining three pairs to LED. As the gate masts both had bells on them, CSX also just simply disconnected the Safetran Type 3 e-bell here (it appears), but left it abandoned in place on top of the cantilever rather than removing it. Definitely a bit of an unusual upgrade, but it is one I've seen done before, including by CSX themselves. Either way, since then, nothing else too major appears to have changed to this crossing, which is nice to see. I must say, this crossing does look a bit neat with the gate masts installed in front of the cantilevers as well, kind reminds me of older MoPac and UP gated cantilever installs, and it's certainly not something you typically see with a CSX crossing. The front-left mast light on the closer signal has also had a fair amount of paint flake off of its background for some reason as well.
https://www.rxrsignals.com/Kentucky/A-K/Hopkinsville/1/
