Old signal in Colorado.
illinoistrains
Post by illinoistrains »
http://railpictures.net/viewphoto.php?id=345723
Check out this old signal!
It looks like the lights are those GRS lights with the 8" front and the smaller lights in the back (The ones with only 1 light bulb.)
Also, check out the steep incline in the tracks right before the crossing.
Visit my website to see my complete collection of over 2,200 train pictures:
http://cnfan1.rrpicturearchives.net/
Robert_Gift
Re: Old signal in Colorado.
Post by Robert_Gift »
illinoistrains wrote:... It looks like the lights are those GRS lights with the 8" front and the smaller lights in the back (The ones with only 1 light bulb.)...
What do you mean: "1 light bulb".?
I like the black crossbuck.
Have never seen a "1 track" sign before. Joke?
I'm now self-employed but my boss is a moron.
My life is an open book. Unfortunately, I'm illiterate.
My patients' arrhythmias straighten themselves out!!
illinoistrains
The Lights i am thinking of have one light bulb and a reflector like a normal light. but a hole in the reflector so the rear light lights up without another bulb.
BTW. 1 track signs are common on the NS
Here is a picture of an NS crossing in Springfield with a 1 track sign
Robert_Gift
illinoistrains wrote:The Lights i am thinking of have one light bulb and a reflector like a normal light. but a hole in the reflector so the rear light lights up without another bulb.
How interesting.
So, if the sun rises or sets behind an east or west-oriented lamp, light could shine through?
Never heard of such a lamp.
My WigWag signal has the same defect in design - one bulb between the two red lens: (*)
Also interesting seeing Triple Crown train. Such little distance between cars makes a more aerodynamically-slippery train.
Robert_Gift
KLM92 wrote:Another big issue with GRS XB and XD light heads is that the backlight can not be aimed. If you look at the picture below you can see how light heads are aimed... With GRS XB and XD light heads, if the lights have to be aimed in at oncoming traffic the backlights will not face traffic in the other direction. They will aim out away from the road unless it curves sharply to the right. That was one of the major downfalls with that design of light head. US&S also made light heads with this design.
As far as the false illumination goes, GRS XB and XD lights have a reflector like a standard light head except that they have a hole in the middle. The light bulb shines through the hole and illuminates the backlight. The reflector blocks light shining through the backlight for the most part. If there was still an issue with light shining through the backlight assembly they would install a Phankill unit. A Phankill unit minimizes illumination by reflection from an external light.
Thanks, Kody.
Just a little bright sunlight passing through the reflector'small port could make the light appear to be on. Sunlight is very powerful.
How does the Phankill unit work?
Why did they install bird nest foundations on the lamps pictured?
