Earlier today, I stopped at the Standish Historical Depot & Welcome Center and found this bell that is activated by a push button, I tried to do some research on what bell it was but I could not find out.
Bell at the Standish Historical Depot & Welcome Center
Last edited by ToledoRailfan on Sat Apr 11, 2015 2:40 pm, edited 3 times in total.
Re: \Bell at the Standish Historical Depot & Welcome Center
You can't use HTML code on forums
I tried doing that because for some reason, the [YouTube][/YouTube] method stopped working for me.ZachL wrote:You can't use HTML code on forums
Works for me.?
I fixed it, I think it did not work because I used https instead of http.ZachL wrote:
Works for me.?
Looks to be a WRRS bell, but it could be a Federal Signal, early WCH, or even a GRS mechanical bell.
BTW, was there a latch sticking out of the left-hand side of the bell (opposite the hinge)? If not, then it's very likely that it's a MI or US&S mechanical bell.
Crossingman18
That's a WCH bell with a off tone gong.
