These road markings look kind of strange. https://www.google.com/maps/@34.0044588 ... 312!8i6656freebrickproductions wrote:Signal maintenance:
https://www.google.com/maps/@34.004429, ... 312!8i6656
Google Maps Scavenger Hunt
- ToledoRailfan
Crossing is activated here: https://www.google.com/maps/@34.0047245 ... 312!8i6656freebrickproductions wrote:Signal maintenance:
Probably trying to keep vehicles (trucks especially) from going into the drainage ditch there.ToledoRailfan wrote:These road markings look kind of strange. https://www.google.com/maps/@34.0044588 ... 312!8i6656
And here:cabman701 wrote:Crossing is activated here: https://www.google.com/maps/@34.0047245 ... 312!8i6656freebrickproductions wrote:Signal maintenance:
https://www.google.com/maps/@34.0045195 ... 312!8i6656
Also, going back to 2013 shows the crossing in action!
https://www.google.com/maps/@34.0046287 ... 312!8i6656
https://www.google.com/maps/@34.0045496 ... 312!8i6656
Interesting case out of Plant City here...
2011: https://www.google.com/maps/@28.0128297 ... 312!8i6656
2015: https://www.google.com/maps/@28.0128554 ... 312!8i6656
The mast was downgraded!
Needless to say though, because the entire crossing got upgraded by 2016:
https://www.google.com/maps/@28.0129095 ... 312!8i6656
The mechanical bell was also rotated between 2011 and 2015.ZachL wrote:Interesting case out of Plant City here...
The mast was downgraded!![]()
- McK&H.Aust
Not sure what happened but it seems that the lights on this crossing in Kansas City, Missouri were damaged by the power pole
https://www.google.com/maps/@39.0971849 ... 6656?hl=en
https://www.google.com/maps/@39.0971864 ... 6656?hl=en
Looks like signal maintainers are also present https://www.google.com/maps/@39.0971864 ... 6656?hl=en
Going back to 2011 you can see where the pole used to be. The mechanical bell was also removed some time after this. https://www.google.com/maps/@39.0971864 ... 6656?hl=en
Some active shots from 2011 https://www.google.com/maps/@39.0971823 ... 6656?hl=en
https://www.google.com/maps/@39.0971924 ... 6656?hl=en
https://www.google.com/maps/@39.0971897 ... 6656?hl=en
Looks like someone hit the pole, which knocked it into the lights.McK&H.Aust wrote:Not sure what happened but it seems that the lights on this crossing in Kansas City, Missouri were damaged by the power pole
It was caught in action in 2014 as well!McK&H.Aust wrote:Some active shots from 2011 https://www.google.com/maps/@39.0971823 ... 6656?hl=en
https://www.google.com/maps/@39.0971839 ... 6656?hl=en
- McK&H.Aust
Sure must be a busy crossing, nice to see the new pole and the lights fixed. It's interesting how GSV went for 3 years between visits, then came past twice in 2 months.ZachL wrote:It was caught in action in 2014 as well!McK&H.Aust wrote:Some active shots from 2011 https://www.google.com/maps/@39.0971823 ... 6656?hl=en
I followed further along the line and found this crossing with both Stop and Yield signs https://www.google.com/maps/@38.7048239 ... 6656?hl=en
That seems a bit confusing, I wonder why it was done.
- ToledoRailfan
Here is a pretty cool old signal for a side street at this crossing. https://www.google.com/maps/@37.2719795 ... 6656?hl=en
Active crossing, Roanoke Virginia. https://www.google.com/maps/@37.272667, ... 6656?hl=en
This train had a caboose, it is probably a local. https://www.google.com/maps/@37.2727466 ... 6656?hl=en
Active crossing, South Salt Lake, Utah. https://www.google.com/maps/@40.7126485 ... 6656?hl=en
Here is a cool old yet odd looking cantilever signal, the signal is now gone because this crossing is now used by the Sugar House Streetcar (S-line). https://www.google.com/maps/@40.7224583 ... 6656?hl=en
Active crossing, Vanceburg, Kentucky. https://www.google.com/maps/@38.6023423 ... 6656?hl=en https://www.google.com/maps/@38.6022821 ... 6656?hl=en
https://www.google.com/maps/@38.6022521 ... 6656?hl=en
https://www.google.com/maps/@38.6022266 ... 6656?hl=en
https://www.google.com/maps/@38.6023056 ... 6656?hl=en
Here is an odd signal, it is like this due to a utility pole. https://www.google.com/maps/@38.6016138 ... 6656?hl=en
This crossing also has two mast signals for each road. https://www.google.com/maps/@38.6013729 ... 6656?hl=en https://www.google.com/maps/@38.6016282 ... 6656?hl=en
Strange crossing ID tag. https://www.google.com/maps/@38.5983561 ... 6656?hl=en
