TrickyMario7654 wrote:A pedestrian crossing barrier that's red and white instead of the usual yellow at Murray Road, Preston.
https://www.google.com.au/maps/@-37.737 ... 312!8i6656
Sadly, they've since replaced it with pedestrian gates.
Looks like they were in the process of installing the newer style as Street View went on by:
TrickyMario7654
Post by TrickyMario7654 »
I noticed that...
TrickyMario7654
Found a crossing with a Wishbone gate and a newer 'flat' gate in Morwell.
https://www.google.com.au/maps/@-38.235 ... 312!8i6656
They've since replaced the wishbone gate with a newer gate.
Looks like Street View captured Florida Avenue in action!
https://www.google.com/maps/@28.0441232 ... 312!8i6656
Although since it's been added, it's been upgraded as well to a quad setup:
https://www.google.com/maps/@28.0448163 ... 312!8i6656
cabman701 wrote:This would be my guess: https://www.google.com.au/maps/@-37.771 ... 312!8i6656
I didn't see the nearby bus stop, thanks for answering my question.
I was actually referring to the traffic light blocking where the crossbuck would normally be. But it would help with visibility too if a bus was there. :TUP2:
Active crossing in Montgomery, AL, on the northern end of the CSX M&M and Dothan Subs:
https://www.google.com/maps/@32.3855373 ... 6656?hl=en
https://www.google.com/maps/@32.3855282 ... 6656?hl=en
Local just down the tracks:
The semaphore in Montgomery is still there!
https://www.google.com/maps/@32.364439, ... 6656?hl=en
Classic signals:
https://www.google.com/maps/@32.4255397 ... 6656?hl=en
More old signals:
https://www.google.com/maps/@32.4638164 ... 6656?hl=en
Another very classic crossing:
https://www.google.com/maps/@32.4708412 ... 6656?hl=en
Another pair of classics:
https://www.google.com/maps/@32.7892627 ... 6656?hl=en
Strange-looking signal:
https://www.google.com/maps/@32.7887558 ... 6656?hl=en
Another pair of classic signals! This is on the CSX line with the Semaphore. Not sure if it's a branch line or a main line:
https://www.google.com/maps/@32.3305014 ... 1664?hl=en
A 1980s CSX install further down the line in Selma, AL!
https://www.google.com/maps/@32.3581386 ... 6656?hl=en
Another 1980s CSX install, this time gateless!
https://www.google.com/maps/@32.3631215 ... 6656?hl=en
And here's the 8th WCH e-bell in Alabama:
https://www.google.com/maps/@32.3720884 ... 6656?hl=en
TrickyMario7654
freebrickproductions wrote:Active crossing in Montgomery, AL, on the northern end of the CSX M&M and Dothan Subs:
Speaking of Montgomery, AL...
Anyways, I found this Teardrop bell at Corrigan Road, Noble Park which is not used. A Westinghouse bell (as seen on the gate mast) is used instead. But for some reason, they haven't removed the teardrop bell and it just sits there disused.
https://www.google.com.au/maps/@-37.961 ... 312!8i6656
Off to the US were I found this 11-track crossing in Des Moines, Iowa.
https://www.google.com.au/maps/@41.5870 ... 312!8i6656
Found this crossing in Tasmania with a WCH E-Bell.
https://www.google.com.au/maps/@-41.438 ... 312!8i6656
Probably only of the few crossings in Tasmania with barriers! Most of there crossings have just flashing lights and bells.
https://www.google.com.au/maps/@-42.721 ... 312!8i6656
Found this crossing in South Australia with a home-made looking "STOP ON RED SIGNAL" sign. Those lights also look big and bulky!
https://www.google.com.au/maps/@-33.791 ... 312!8i6656
Another "STOP ON RED SIGNAL" that looks home-made.
https://www.google.com.au/maps/@-35.724 ... 312!8i6656
Another crossing with those big bulky lights (have no idea what they're called).
https://www.google.com.au/maps/@-32.627 ... 312!8i6656
At Australian level crossings, we have these signs under the signals that say "RAILWAY" & "CROSSING".
Typically, they're either stacked on top of each other...
https://www.google.com.au/maps/@-37.790 ... 312!8i6656
Or arranged so "RAILWAY" is on the left side of the road and "CROSSING" is on the right side of the road...
https://www.google.com.au/maps/@-37.778 ... 312!8i6656
But I found this one that's arranged where it's printed out on one whole sign!
https://www.google.com.au/maps/@-32.500 ... 328!8i1664
Found this odd looking boom gate at Wagga Wagga.
https://www.google.com.au/maps/@-35.122 ... 312!8i6656
This one has separate barriers for the turning lane at this intersection...
https://www.google.com.au/maps/@-36.615 ... 312!8i6656
I've talked about the Ryans Road level crossing before. But basically, when the built the Pakenham bypass, they had to close the road at the crossing. But they forgot to remove the signals and as a result, the signals were left there protecting no one!
They were still there in 2010. (It's even active!)
https://www.google.com.au/maps/@-38.083 ... 312!8i6656
They've since been removed, but still pretty funny.
ToledoRailfan
Post by ToledoRailfan »
TrickyMario7654 wrote: Off to the US were I found this 11-track crossing in Des Moines, Iowa.
There is this cool old out of service semaphore next to the crossing! https://www.google.com.au/maps/@41.5872 ... 312!8i6656
Kind of an odd way to have side lights. https://www.google.com/maps/@48.2478494 ... 312!8i6656
Here is a cool 8'' signal on display in St. Thomas, Ontario with a WRRS mini bell and a crossbuck from before the ones with the red outlining were in use. https://www.google.com/maps/@42.7789117 ... 6656?hl=en
https://www.google.com/maps/@42.7791385 ... 6656?hl=en
Here is something you don't see everyday, this underpass was replaced by a crossing! https://www.google.com/maps/@42.7781682 ... 6656?hl=en
https://www.google.com/maps/@42.7790391 ... 6656?hl=en
https://www.google.com/maps/@42.7778826 ... !1e3?hl=en
