Tracks out of service
TrickyMario7654
Re: Tracks out of service
Post by TrickyMario7654 »
cabman701 wrote:I wholeheartedly agree on preserving equipment after the tracks go dormant. As Brick showed in Courtland, Alabama... all of the equipment (including the relay box) can be moved from one crossing to another and put back into service. I would have to think this is a cheaper alternative than purchasing brand new equipment.
Sadly, they didn't get the message when they removed the crossings at Mitcham. (Photo courtesy of Vicsig)
Here's another level crossing removal video I disapprove of... :TDOWN:
Post by ZachL »
chris96 wrote:
freebrickproductions wrote:Not sure if this was posted before, but West Sacramento, CA:
https://www.google.com/maps/@38.5665321 ... 312!8i6656
I don't understand why railroads sometimes go to the effort of turning the lights around and installing a "tracks out of service" sign when they could just remove the equipment all together and put it in safe storage. The same thing also happened at this crossing nearby:
https://www.google.com/maps/@38.5964936 ... 312!8i6656
I used to think this only happened on lines that had the possibility of being used again in the future (as a way to protect the equipment temporarily, but still keep it in place if needed). But I've see this happen at crossings where the tracks have been totally ripped up!
More often than not, it could have something to do with the potential of returning service in the future. However, over time, plans fall and they don't happen. Also, I'm pretty sure that it's different departments within a railroad that handle equipment removal than track removal as well.
chris96
Post by chris96 »
There's heaps of disused crossings in the industrial areas of LA, particularly around Commerce. Most of these tracks just served local factories:
https://www.google.com.au/maps/@33.9229 ... 312!8i6656
https://www.google.com.au/maps/@33.9608 ... 312!8i6656
https://www.google.com.au/maps/@33.9246 ... 312!8i6656
https://www.google.com.au/maps/@33.9907 ... 312!8i6656
https://www.google.com.au/maps/@33.9950 ... 312!8i6656
https://www.google.com.au/maps/@33.9970 ... 312!8i6656
https://www.google.com.au/maps/@33.9968 ... 312!8i6656
Most unusual:
https://www.google.com.au/maps/@34.0021 ... 312!8i6656
This place even has crossings over crossings! :LOL4: :
https://www.google.com.au/maps/@34.0040 ... 312!8i6656
There are way too many crossings for me to post here. I suggest you check out this area on Google maps. It's absolutely teeming with interesting crossings!
TrickyMario7654
chris96 wrote:This place even has crossings over crossings! :LOL4: :
OMG! So many crossings!
While were at it. Here's this crossing that runs through this carpark at the Melbourne wharf.
https://www.google.com.au/maps/@-37.820 ... 312!8i6656
https://www.google.com.au/maps/@-37.819 ... 312!8i6656
Sadly, all the tracks have now been ripped out.
cabman701
Post by cabman701 »
This I believe is the old Chicago & North Western line in Sheboygan, Wisconsin. They liked Griswold signals it appears!
These are no longer there unfortunately: https://www.google.com/maps/@43.7454275 ... 328!8i1664.
The relay box was though 3 years ago: https://www.google.com/maps/@43.7454281 ... 312!8i6656
This one is on the site: http://www.rxrsignals.com/Wisconsin/R-Z ... gan/Union/
It's sidelights are gone: https://www.google.com/maps/@43.7320904 ... 312!8i6656
And it's brother across the tracks? Well... https://www.google.com/maps/@43.7320893 ... 312!8i6656
More that fell between 2007 and 2013: https://www.google.com/maps/@43.7298495 ... 328!8i1664
https://www.google.com/maps/@43.7298506 ... 328!8i1664
Again, the relay box was still there 3 years ago: https://www.google.com/maps/@43.7296859 ... 312!8i6656
TrickyMario7654
Leftover track at Toora, VIC from when the South Gippsland rail line ran all the way up to Yarram. The line beyond Leongatha was closed in June 1992 after the Barry Beach Goods train (the last thing that still used the line beyond Leongatha) ceased using the line.
https://www.google.com.au/maps/@-38.665 ... 328!8i1664
Found this crossing on an out of service line in Mount Gambier, SA that has "RAILWAY CROSSING NOT IN USE" signs. One signal is missing the lights too!
https://www.google.com.au/maps/@-37.831 ... 312!8i6656
The signs weren't there in 2008, though the lights were still missing on one of the signals.
https://www.google.com.au/maps/@-37.831 ... 328!8i1664
Same story with a nearby crossing, those lights have taken quite a beating on this signal! The signal on the other side has been torn out and replaced with this sign containing a crossbuck and a "RAILWAY CROSSING NOT IN USE" sign.
https://www.google.com.au/maps/@-37.832 ... 312!8i6656
This one has this weird support beam running from the top to the base of the signal.
Vintage looking passive crossing.
https://www.google.com.au/maps/@-37.857 ... 328!8i1664
Another vintage crossing. Sadly, the signs had been removed by 2010.
https://www.google.com.au/maps/@-37.857 ... 312!8i6656
The line crosses the SA/VIC border and thus, all findings below this line are from VIC.
The signs look much more newer at this passive crossing.
https://www.google.com.au/maps/@-37.867 ... 328!8i1664
Another passive crossing with newer signs. One of them is missing the crossbuck for some reason.
https://www.google.com.au/maps/@-37.920 ... 328!8i1664
Very old looking Flashing Lights setup with vintage lights and a McK&H teardrop bell.
https://www.google.com.au/maps/@-38.125 ... 328!8i1664
Another crossing with old signals. One side is missing the crossbuck as well!
https://www.google.com.au/maps/@-38.127 ... 328!8i1664
The line then rejoins the main line to Portland shortly after the last crossing listed above.
chris96 wrote:There are way too many crossings for me to post here. I suggest you check out this area on Google maps. It's absolutely teeming with interesting crossings!
Crossings such as this one...
https://www.google.com/maps/@33.9990859 ... 6656?hl=en
chris96
Post by chris96 »
Very much like that. Amazing find!! :TUP1:
busman_49
Post by busman_49 »
Dryden Rd, Moraine, OH:
https://www.google.com/maps/@39.6903579 ... 312!8i6656
(the SORS signs are unusual for Ohio!)
It looks like it's been cut off from the mainline, or badly overgrown:
https://www.google.com/maps/place/Dryde ... 84.2231158
chris96
Post by chris96 »
busman_49 wrote:Dryden Rd, Moraine, OH:
I'm a little puzzled by what these square boxes are on the back of the bells:
https://www.google.com/maps/@39.6903563 ... 312!8i6656
https://www.google.com/maps/@39.6902716 ... 312!8i6656
From the front they just look like standard WCH M-Bells.
Post by ZachL »
Those are motor bells! Instead of being powered by magnets (like a standard mechanical bell), they're run by a motor.
