Lily Flagg Road, Huntsville, AL
Signal on the left: 2 pairs of WRRS 8 inch lights.
Signal on the right: 2 pairs of WRRS 8 inch lights.
The bell is a Safetran mechanical bell mounted on the relay case.
Re: Lily Flagg Road, Huntsville, AL
Got another video from the other side yesterday, this time with one of the HMCR's new B39-8s making an appearance!
Sounds like the bell was slowed down a bit since I was last here.
And this time around, we get two B39-8s running lite.
The damaged light has recently fallen off of the signal:
If you look closely, you can see the fallen WRRS 8 inch light next to the bottom of the signal.
The HMCR might not replace the damaged light as they have a brand new mast signal that's being shipped to replace the one on the right in the video.
Still missing a light:
The new signal to replace the damaged one has arrived, but the HMCR hasn't had time to install it yet.
The Parkway's construction is advancing nicely. Video from July 19th, 2017:
Still has the damaged signal:
However, the new signal may be installed by the end of the year as the construction on the Parkway is a year ahead of schedule.
*originally recorded on 12-13-18*
The bell is a Safetran mechanical bell located on the relay case.
The only change to this crossing since I last recorded it was that a WRRS 8 inch light was installed on the near signal here a few months back. The light was re-used from Bob Wallace Avenue.
http://www.rxrsignals.com/Alabama/G-Q/H ... Lily_Flagg
