Google Maps Scavenger Hunt
TrickyMario7654 wrote:
freebrickproductions wrote:
TrickyMario7654 wrote:Anyone know why there's a crossing light facing towards the track at this crossing?
https://www.google.com.au/maps/@38.6329 ... 312!8i6656
Crossing indicator. Lets the train crews for that light rail/commuter rail line know that the crossing signals have activated and if the gates have lowered or not as well.
Seems a bit strange that they would use a crossing light rather than a beacon... :Confused:
Whatever works for them. Besides, this works a bit better since it's easier to wire in through the signal masts.
Post by ZachL »
In addition to that, visibility is probably higher as well than just a small beacon.
cabman701
Post by cabman701 »
Muncie, Indiana.
TrickyMario7654
Post by TrickyMario7654 »
Here's something you don't see everyday, a cantilever signal being replaced with a mast signal! This crossing at Diggers Rest in Victoria had two cantilever signals in 2010 (with newer 'flat' gates and Hybrid bells).
https://www.google.com.au/maps/@-37.626 ... 312!8i6656
Fast forward to 2014, and one of the cantilever signals have been replaced with a mast signal! An extra signal was also installed in its place.
The other side is pretty much the same as before.
Out of interest, the 'flat' gates were replaced with A-gates and the Hybrid bells were swapped out for E-Bells. I figured that all these changes would have been made in 2012 when they extended suburban services to Sunbury (from Watergardens/Sydenham station).
Here's another oddity I found. This crossing has "GIVE WAY TO TRAINS" signs even though there's light and bells at this crossing! :Blink:
https://www.google.com.au/maps/@-38.340 ... 328!8i1664
https://www.google.com.au/maps/@-38.339 ... 328!8i1664
By 2009, someone probably noticed the signs and removed them later. They also replaced the Hybrid bell with an E-Bell...
https://www.google.com.au/maps/@-38.340 ... 312!8i6656
When GSV revisited the crossing in 2013, the crossing had been upgraded to a gated crosssing. Seems like a waste of money to replace the bell if the whole signals themselves were gonna get replaced.
The same thing happened at this crossing further down the line. In 2007, there's a McK&H Teardrop bell at the location.
https://www.google.com.au/maps/@-38.364 ... 328!8i1664
By 2009, out with the McK&H Teardrop, in with the GS E-Bell!
https://www.google.com.au/maps/@-38.364 ... 312!8i6656
By 2013, crossing upgraded with gates!
TrickyMario7654 wrote:Here's something you don't see everyday, a cantilever signal being replaced with a mast signal! This crossing at Diggers Rest in Victoria had two cantilever signals in 2010 (with newer 'flat' gates and Hybrid bells).
I know CSX has done that a fair amount.
TrickyMario7654
Each time GSV went through this crossing, the bell was different!
In 2007, it had a McK&H Teardrop bell...
https://www.google.com.au/maps/@-38.044 ... 328!8i1664
By 2010, it had been replaced with a WCH Mechanical Bell.
https://www.google.com.au/maps/@-38.044 ... 312!8i6656
By 2015, that had been replaced with a Safetran E-Bell!
Seems stupid to install a new Mechanical bell, only to replace it with an E-Bell a few years later...
Partly installed flashing lights signals...
https://www.google.com.au/maps/@-37.939 ... 328!8i1664
A few years later...
https://www.google.com.au/maps/@-37.939 ... 312!8i6656
Post by ZachL »
ToledoRailfan wrote:Active crossing, Panhandle, Texas:
https://www.google.com/maps/@35.3546666 ... 6656?hl=en
https://www.google.com/maps/@35.3545116 ... 6656?hl=en
It could be malfunctioning because I could not find a train.
Actually, there is a train:
https://www.google.com/maps/@35.3546635 ... 6656?hl=en
The signals are deactivated once Street View passes on by:
https://www.google.com/maps/@35.3546619 ... 6656?hl=en
Post by ZachL »
Classic cantilever signals near Niagara Falls:
https://www.google.com/maps/@43.0831549 ... 312!8i6656
Another pair of classics:
https://www.google.com/maps/@43.1303553 ... 312!8i6656
Some really classic signals here!
https://www.google.com/maps/@43.1223647 ... 312!8i6656
A couple of older gated signals here across the border, though the original 8 inch lights have been replaced:
https://www.google.com/maps/@43.1328223 ... 312!8i6656
https://www.google.com/maps/@43.1334211 ... 312!8i6656
More classic signals back in New York state:
https://www.google.com/maps/@42.9746597 ... 312!8i6656
https://www.google.com/maps/@42.9749435 ... 312!8i6656
