Level crossing in Mombaruzzo Station (Asti, Piamonte - Italy) at night, two trains passage and raising barriers. Taken shortly before 24.00 hours on 25 November 2016 with dashcam. Spectral trains.
https://www.youtube.com/watch?v=3Lz8EvUmtl8
Rail crossing in Mombaruzzo (Asti-Italy)
MaxDriveEXperience
Last edited by MaxDriveEXperience on Wed Nov 30, 2016 3:20 pm, edited 1 time in total.
My youtube channel: https://www.youtube.com/channel/UCz0Mb4 ... Hgllux3B3w
If you like please subscrive
Re: Rail crossing in Mombaruzzo (Asti-Italy)
Just FYI, make sure to remove the s from https at the beginning of the URL when using the YouTube tags. I've fixed the post for you.
MaxDriveEXperience
Thanks!freebrickproductions wrote:Just FYI, make sure to remove the s from https at the beginning of the URL when using the YouTube tags. I've fixed the post for you.
Is there perhaps any way to get around this by either updating the plugin or changing the code on the plugin? It's an inconvenience now that YouTube defaults to using https...freebrickproductions wrote:Just FYI, make sure to remove the s from https at the beginning of the URL when using the YouTube tags. I've fixed the post for you.
I'd have to talk to Gillson about that.ZachL wrote:Is there perhaps any way to get around this by either updating the plugin or changing the code on the plugin? It's an inconvenience now that YouTube defaults to using https...freebrickproductions wrote:Just FYI, make sure to remove the s from https at the beginning of the URL when using the YouTube tags. I've fixed the post for you.
