Mineral Springs Road - NICTD
- Joosh
I like this old setup this local commuter line has.
Re: Mineral Springs Road - NICTD
Just FYI, you use the whole URL, but you have to remove the S from https:// to make it work with the YouTube tags.
- Joosh
Ah, okay. Been a while since I've used BBC code, so I appreciate the info.
No problem.Joosh wrote:Ah, okay. Been a while since I've used BBC code, so I appreciate the info.
- TrickyMario7654
Nice videos. Sort of reminds me of this crossing in my local area.
Looks like that crossing could use a new flasher relay... especially in the first and second videos. The one light barely even comes on before it switches back. Guessing maybe the cold weather has an effect on it?
It's still not timed properly in the third video as well; in that video the trees and grass appear to all have green indicating warmer temps.cabman701 wrote:Looks like that crossing could use a new flasher relay... especially in the first and second videos. The one light barely even comes on before it switches back. Guessing maybe the cold weather has an effect on it?
- Joosh
Yeah, the third video was one I took in June 2013. The first two were took in December 2016 and January 2016, respectively.
