My new backyard decoration
WRRS-Chicago
Post by WRRS-Chicago »
So last year I finally got the bug to go through put one of my flasher signals up. Keep in mind I've never done this before. Never did anything with concrete. As such I was very very careful to fully research what I was doing. I had 811 come out to verify nothing was in the ground where I wanted to dig. I carefully measured and cut four sheets of plywood to create the form for the footing. I dug the 27 square foot hole with a shovel. I used 1.25" conduit to run electric through the concrete. I purchased four 1" x 24" galvanized anchor bolts. I added rebar between them. I had seen pictures of how bolts were secured in place as concrete was added. I pounded in an 8-foot galvanized rod into the ground and ran a braided copper line between it and one of the anchor bolts. Yes, I should have painted the mast before putting anything on it but my deadline was the first snow, which I barely made, and I didn't have paint yet (I went with Rustoleum aluminum, which is a bit too shiny for my taste). As it is, much of what is currently on the signal is temporary. My initial plan was to put up a teardrop bell, US&S lights, cast two-sided crossbuck, and cat eyes Stop on Red Signal sign. A few of those things need to be primed and painted yet. The mini bell was heavy enough to man-handle up the ladder. To put that incredibly heavy stuff up there will require a cherry picker or scaffolding. The lights are aluminum WRRS. I can wait as I'm happy with this compromise for now.
ToledoRailfan
Re: My new backyard decoration
Post by ToledoRailfan »
Looks great! :Clap:
Post by ZachL »
Something seems a bit off with the flasher timing, but other than that it's amazing! Nice job! :TUP1:
cabman701
Post by cabman701 »
ZachL wrote:Something seems a bit off with the flasher timing, but other than that it's amazing! Nice job! :TUP1:
Actually on older signals, which this is modeled after, the flashing rate is usually slower and in some cases a little uneven (meaning one light stays on longer than the other). Makes it more authentic in my option. Nice job!
Post by ZachL »
Guess you learn something new everyday! :Wink:
WRRS-Chicago
Truth be told I have three US&S FN-16a flasher relays, and one WCH solid state relay. One of the US&S flashes pretty evenly, and for now I keep that at the studio in case I need it. The WCH is pretty even and the rate can be adjusted. I've heard the FN-16a can be tweaked for more even flashing. I suppose I'd prefer that but as cabman701 says, there's something more authentic about the unevenness. I should have gotten a shot of the signal starting up because you get that mini-flurry of flashes before the magnetic passive-resistance settles in which you still see at crossings today and then you know you've got decades-old -- yet perfectly reliable -- technology in that shed.
