Google Maps Scavenger Hunt (Traffic signals and signs)
Talk about other non-signal stuff here. Make sure to obey the rules though.
ToledoRailfan
Post by ToledoRailfan »
I thought there should be a topic that is like the Google Maps Scavenger Hunt topic but for traffic signals and signs. Here are some of my finds.
Temporary traffic signals. https://www.google.com/maps/@39.6499029 ... 6656?hl=en https://www.google.com/maps/@39.6512088 ... 6656?hl=en
Vintage Y-Y-R signals. https://www.google.com/maps/@41.2436979 ... 6656?hl=en https://www.google.com/maps/@41.2433791 ... 6656?hl=en
The signals pointing toward the fire station are G-Y-R signals. https://www.google.com/maps/@41.2435171 ... 6656?hl=en
Vintage incandescent signals with the red section being the larger than the yellow and green section. https://www.google.com/maps/@41.3520483 ... 6656?hl=en
https://www.google.com/maps/@41.3521202 ... 6656?hl=en https://www.google.com/maps/@41.3521202 ... 6656?hl=en https://www.google.com/maps/@41.3522889 ... 6656?hl=en https://www.google.com/maps/@41.3524171 ... 6656?hl=en
There are also vintage worded pedestrian signals here.
https://www.google.com/maps/@41.3523389 ... 6656?hl=en https://www.google.com/maps/@41.3522889 ... 6656?hl=en https://www.google.com/maps/@41.3521678 ... 6656?hl=en
https://www.google.com/maps/@41.3520515 ... 6656?hl=en
A pair of vintage 4-way signals! https://www.google.com/maps/@40.6353843 ... 6656?hl=en https://www.google.com/maps/@40.6355099 ... 6656?hl=en
Another pair. https://www.google.com/maps/@40.6379827 ... 6656?hl=en https://www.google.com/maps/@40.6379777 ... 6656?hl=en
TrickyMario7654
Re: Google Maps Scavenger Hunt (Traffic signals and signs)
Post by TrickyMario7654 »
An old traffic Wig-Wag near Tooronga station in Melbourne with a vintage Pedestrian Crossing sign!
https://www.google.com.au/maps/@-37.850 ... 312!8i6656
By 2013, they had replaced with a newer one, but reused the older pole.
Came across this intersection last night for the first time. The road is divided by a canal so there are 2 sets of lights. Originally both sets of lights were on span wire like this:
https://www.google.com/maps/@27.7989717 ... 312!8i6656
Apparently, that was causing some trouble, as the 2nd set of lights will change green when traffic turning from the opposite road gets a green arrow (so as not to congest the middle of this intersection).
Now, the 2nd set of lights have been removed from the span wire and placed on the pole. They put both lights heads next to each other, angled them a bit, and put visors in both the red and green lights so that they cannot be easily seen for traffic stopped at the first set of lights. Just thought this was an interesting solution.
https://www.google.com/maps/@27.7989976 ... 312!8i6656
https://www.google.com/maps/@27.7989336 ... 312!8i6656
Joosh
Post by Joosh »
Joosh wrote:Some more 4-way clusters in Ohio: :TUP2:
https://www.google.com/maps/@41.163281, ... 56!6m1!1e1
12 inch worded peds there as well! :TUP2:
12" worded pedestrians were actually somewhat common around Tampa before they replaced them all with countdown signals.
