Anyone else getting popups?
- brett nc railfanner
I'm getting weird pop-ups, With rxrsignals in the URL. Is anyone else getting pop-ups?
Re: Anyone else getting popups?
I haven't. Have you tried running a scan with an antivirus on your computer? It's likely that you have some adware on your system.
I've did that, It does not do anything.freebrickproductions wrote:I haven't. Have you tried running a scan with an antivirus on your computer? It's likely that you have some adware on your system.
Last edited by brett nc railfanner on Fri Mar 10, 2017 12:48 am, edited 1 time in total.
I'm still not getting anything, even with the pop-up/ad blockers disabled and in both Chrome and IE 11. What antivirus did you use?brett nc railfanner wrote:I've did that, I does not do anything.freebrickproductions wrote:I haven't. Have you tried running a scan with an antivirus on your computer? It's likely that you have some adware on your system.
Also, what kinds of pop-ups are you getting?
I've used Malwarebytes Adwcleaner and Hitman pro. Also the main pop up is Coupon time and sometimes when I click on something a new tab pops up with Rxrsignals as a part of the URL.freebrickproductions wrote:I'm still not getting anything, even with the pop-up/ad blockers disabled and in both Chrome and IE 11. What antivirus did you use?brett nc railfanner wrote:I've did that, I does not do anything.freebrickproductions wrote:I haven't. Have you tried running a scan with an antivirus on your computer? It's likely that you have some adware on your system.
What browser are you using? Do you have any extensions enabled?brett nc railfanner wrote:I've used Malwarebytes Adwcleaner and Hitman pro. Also the main pop up is Coupon time and sometimes when I click on something a new tab pops up with Rxrsignals as a part of the URL.freebrickproductions wrote:I'm still not getting anything, even with the pop-up/ad blockers disabled and in both Chrome and IE 11. What antivirus did you use?brett nc railfanner wrote:I've did that, I does not do anything.freebrickproductions wrote:I haven't. Have you tried running a scan with an antivirus on your computer? It's likely that you have some adware on your system.
Admininstration team: I would check coding on the pages as well. Websites do get hacked and malicious code can often be inserted despite it not being authorized or done by y'all.
I use chrome and I have deleted all of the extensions that look fishy.freebrickproductions wrote:What browser are you using? Do you have any extensions enabled?brett nc railfanner wrote:I've used Malwarebytes Adwcleaner and Hitman pro. Also the main pop up is Coupon time and sometimes when I click on something a new tab pops up with Rxrsignals as a part of the URL.freebrickproductions wrote:I'm still not getting anything, even with the pop-up/ad blockers disabled and in both Chrome and IE 11. What antivirus did you use?brett nc railfanner wrote:I've did that, I does not do anything.freebrickproductions wrote:I haven't. Have you tried running a scan with an antivirus on your computer? It's likely that you have some adware on your system.
Are you still having the issue? If so, then try adding uBlock Origin to Chrome, as it's an ad blocker and it will probably help keep the pop-ups down. If not, then it was one of those extensions that was causing the issue.brett nc railfanner wrote:I use chrome and I have deleted all of the extensions that look fishy.freebrickproductions wrote:What browser are you using? Do you have any extensions enabled?brett nc railfanner wrote:I've used Malwarebytes Adwcleaner and Hitman pro. Also the main pop up is Coupon time and sometimes when I click on something a new tab pops up with Rxrsignals as a part of the URL.freebrickproductions wrote:I'm still not getting anything, even with the pop-up/ad blockers disabled and in both Chrome and IE 11. What antivirus did you use?brett nc railfanner wrote:I've did that, I does not do anything.freebrickproductions wrote:I haven't. Have you tried running a scan with an antivirus on your computer? It's likely that you have some adware on your system.
I'll ask Gillson to take a look at it.ZachL wrote:Admininstration team: I would check coding on the pages as well. Websites do get hacked and malicious code can often be inserted despite it not being authorized or done by y'all.
Also, if we can get any specific pages where this is occurring at, let us know. It'll help us out to see if it's an issue with someone editing some of the pages on the site.
