Crossing Malfuction/Fails Sightings
TrickyMario7654
Re: Crossing Malfuction/Fails Sightings
Post by TrickyMario7654 »
cabman701 wrote:
ZachL wrote:I've seen instances of gates stuck like that, and of course the crossing active. More often than not, there'd usually be an obstacle preventing the gate from fully rising.
Which in this case appears to be the traffic light cantilever. The cop was able to jostle it loose.
Actually, the traffic light cantilever is quite a distance away from the crossing signal.
https://www.google.com.au/maps/@-38.017 ... 312!8i6656
I guess the Westinghouse gate mechanism was malfunctioning.
brett nc railfanner
Post by brett nc railfanner »
This is odd.
brett nc railfanner
Here are some more.
TrickyMario7654
Another common cause of railroad crossing malfunctions (at least in Melbourne) is power failures or track equipment faults, as was the case with most of the crossings in my area today. The gates were stuck down on McGregor Road, Main Street, and possibly (though I'm not 100% sure) Racecourse Road.
Railtrack
Post by Railtrack »
Southwest Quebec Railfan
Proud owner of 3 crossing bells (WCH 0333, Safetran mechanical and WRRS mini-bell) and a WRRS 8'' light.
My YouTube Channel: https://www.youtube.com/channel/UCUSubL ... mxJ5WtNaQ/
My Facebook Page: http://www.facebook.com/southwestquebecrailfan
TrickyMario7654
Saw one at Cardinia Road today. After a city bound train went through the crossing and the gates rose, the gate on the side we drove on slipped after raising, causing the crossing lights to start flashing for a split second. It got stuck in a lowering/raising potion as a result.
NathanFromEngland
Post by NathanFromEngland »
Tracy Road, Hilliard FL.
One of the gates failed to lock into the wind guard, causing the gate mechanism to make a vibrating sound.
NathanFromEngland wrote:Tracy Road, Hilliard FL.
I don't think that's the cause. Normally a hold clear issue would cause that malfunction (known as "pumping", IIRC), but the US&S Model 75 (shown there) doesn't have that, IIRC. Basically, the gate mechs were just messing up (also the WCH mechanical bell there is now dead, sadly).
NathanFromEngland
I know that, when the crossing activated. You can hear some life out of the bells motor until it stops. Some guy in the comments told me its a WRRS mechanical bell, not a WCH one. But it is a WCH one.
NathanFromEngland
Here is another case of gate mechanism errors.
This crossing in Plainfield Illinois, had a problem with the gate not catching the wind guard and constantly lowering. The gate mechanisms are US&S Model 95's which in my case are the worst gate mechanisms ever made.
