Tracks out of service
ToledoRailfan
Re: Tracks out of service
Post by ToledoRailfan »
NathanFromEngland wrote:Breakwater Road, NJ and Tabernacle Road
https://www.google.co.uk/maps/@38.99701 ... !1e1?hl=en
https://www.google.co.uk/maps/@38.98482 ... !1e1?hl=en
The crossing was owned by Cape May Seashore Lines, however. A train hadn't been by the crossing since 2010, and the line hasn't had its service resumed since March 2012, when vandals stole tracks from them.
NJDOT began the $7.1 million project in February 2011 to reconstruct and widen sections of Route 9 between mileposts 3.9 and 5.7. The two new intersections have been created by extending Tabernacle Road and Breakwater Road to Route 9.
When the road was completed in May 2012, NJDOT installed railroad crossing signals, however. A month later in June 2012, The lights were turned sideways, the gates (excluding the pedestrian gates) were removed, and the Exempt signs were posted below the DO NOT STOP ON TRACKS sign.
Almost all of the equipment at Tabernacle Road is the same, except it has WCH 12x24 inch lights, except one of them have vanished!
Those setups with the intersections are pretty odd as well. I hope they weren't like that when the line was still in service.
https://www.google.co.uk/maps/@38.99701 ... 6656?hl=en
https://www.google.co.uk/maps/@38.98480 ... 6656?hl=en
NathanFromEngland
Post by NathanFromEngland »
freebrickproductions wrote:Panama City, FL, now removed:
https://www.google.com/maps/@30.16788,- ... 1664?hl=en
Further down the line:
https://www.google.com/maps/@30.1589647 ... 6656?hl=en
Did you notice the Bay Line Railroad No Trespassing sign?
https://www.google.com/maps/@30.1678698 ... 6656?hl=en
I guess they used this crossing before they abandoned it, i don't know if it was present day Bay Line Railroad unless the other railroad that got succeeded by its present day name.
No I hadn't! It appears The Bay Line (which is a shortline that runs from Panama City, FL to Dothan, AL) operates over former L&N trackage.
Also, it appears the abandoned signal had Modern Industries 12x24s, WCH mechanical bells, and Safetran gate mechs.
IanMP
Post by IanMP »
Remaining crossbuck on the old track leading To the port of Rimouski QC
https://goo.gl/maps/B6W7iS7B4rw
The tracks were abandoned in early 90's by the CFMG/NBEC, the reason is unknown.
NathanFromEngland
Gleeson Country Road
https://www.google.com/maps/@42.2811123 ... 56!6m1!1e1
This crossing was located on the CN CASO sub, On May 8th 2011, CN announced that operations on the CASO sub would be ceased, Prior to removal of these signals, they had wigwags both sides with i believe is a WCH Mechanical Bell? The signals were removing shortly after the lines closure, the crossing grade was also resurfaced with concrete. Both sides of the tracks are overgrown and there is almost no trace of any equipment from the crossing to be found.
ToledoRailfan
NathanFromEngland wrote:Gleeson Country Road
I don't really live that far from there. If only they were still there. They were the last known wigwags still in service in Canada.
I think this Wigwag at the Elgin County Railway Museum in St. Thomas, Ontario is one of them.
While browsing streetview once I came across this wigwag on display at a tourist railroad and I thought that it also could be one of them but with a different mast.
NathanFromEngland
Stumbled across these defunct Australian Railroad Crossings.
The first crossing pops up just right next to Cranbourne Railway Station where an All-Change will happen.
Cranbourne, VIC
https://www.google.com.au/maps/@-38.101 ... 312!8i6656
The signal on the left unsurprisingly has Alstom LED's in them?
https://www.google.com.au/maps/@-38.106 ... 328!8i1664
The bell there could be either a Modern Industries mechanical bell or either a Safetran or Griswold mechanical bell! It has been repainted though. These signals were removed a few years ago.
https://www.google.com.au/maps/@-38.116 ... 312!8i6656
The bell there is a Westinghouse Teardrop Bell! These signals were removed a few years ago for a road expansion for a housing estate.
Clyde, VIC
https://www.google.com.au/maps/@-38.127 ... 328!8i1664
Approximately 70% of the crossing equipment had vanished when the street view car came by in 2008, the bell i am thinking could be Westinghouse of McK&H
Tooradin, VIC
https://www.google.com.au/maps/@-38.169 ... 328!8i1664
Just a simple Give Way crossing.
Fast forward to 2010, there is a crash barrier protecting the eastbound tracks and a 2014 shot of the crossing shows a access gate to the west with a sign saying "NO UNAUTHORIZED ACCESS"
Dalmore, VIC
https://www.google.com.au/maps/@-38.181 ... 328!8i1664
Once again, another Give Way crossing, fast forward to June 2014 and the "NO UNAUTHORIZED ACCESS" gate has popped up again.
And that is when the tracks end. It would've been for a freight railroad as there aren't any passenger stations across the way. :OhWell:
EDIT: spaced out all crossings to avoid confusion.
NathanFromEngland wrote:Stumbled across these defunct Australian Railroad Crossings.
Cranbourne, VIC
First crossing has a pair of Westinghouse LEDs. Second crossing had a Safetran mechanical bell.
NathanFromEngland
Cranbourne, VIC
Ah okay.
Bit of a shame to put a Safetran M-Bell to waste. Could've reused it.
