Google Street View
Talk about other non-signal stuff here. Make sure to obey the rules though.
ToledoRailfan
Re: Google Street View
Post by ToledoRailfan »
freebrickproductions wrote:
ToledoRailfan wrote:Very short signal!
That's due to an airport being right over here:
https://www.google.com/maps/@40.9746601 ... 6656?hl=en
I never understood why they do that. It isn't often that a plane would be low a enough to hit something like that outside of the airport. And if having a signal that low can work for the railroad, why don't they just do that for most signals. :Confused:
Visibility reasons. Easier to see signals that are as high as the cab if not higher.
ToledoRailfan
I guess this was a "close enough" situation.
NathanFromEngland
Post by NathanFromEngland »
I wonder why the word "WABASH" is written on this bridge. :Confused:
https://www.google.com/maps/@41.0710692 ... 6656?hl=en
ToledoRailfan
NathanFromEngland wrote:I wonder why the word "WABASH" is written on this bridge. :Confused:
Probably because it was installed by the Wabash Railroad.
That's most likely the case. Railroads that built/owned the bridges over roads would usually put their name on the sides of them years ago. A few examples that I'm aware of:
Faded SCL emblems on a bridge along the ATN in Attalla:
https://www.google.com/maps/@34.0184691 ... 312!8i6656
https://www.google.com/maps/@34.0187362 ... 312!8i6656
Also note that there's actually two bridges there, despite there only being one track. That's because it used to be an NC&StL (later L&N) main line.
Hard to tell, but it looks like the NS bridge right up the street in Attalla may have said "Southern" on it once upon a time, though it's very hard to tell:
https://www.google.com/maps/@34.0212686 ... 312!8i6656
An Amtrak logo on this bridge in Birmingham, likely due to the proximity to the old and new Amtrak stations there:
https://www.google.com/maps/@33.5122343 ... 312!8i6656
Some kind of faded logo on this bridge in Birmingham, but the L&N's logo can still be seen:
https://www.google.com/maps/@33.4983191 ... 312!8i6656
The one on the other side hasn't held up as well:
https://www.google.com/maps/@33.4985957 ... 312!8i6656
And this bridge in Irondale (also along the ATN) has some old SAL emblems on it:
https://www.google.com/maps/@33.5369281 ... 312!8i6656
https://www.google.com/maps/@33.5371709 ... 312!8i6656
Over in Atlanta, GA, the Atlanta & Westpoint Railroad's marking is still very much legible on this bridge:
https://www.google.com/maps/@33.719742, ... 312!8i6656
The same can't be said for the other side however, sadly:
https://www.google.com/maps/@33.7193081 ... 312!8i6656
This one hasn't fared well either:
https://www.google.com/maps/@33.7205745 ... 312!8i6656
https://www.google.com/maps/@33.7203037 ... 312!8i6656
And then along the section of the line near Downtown Atlanta, you've got this pair of SCL emblems along a remaining bridge:
https://www.google.com/maps/@33.7642444 ... 312!8i6656
https://www.google.com/maps/@33.7642492 ... 312!8i6656
There was something written on this CSX bridge in Nashville, TN:
https://www.google.com/maps/@36.1697107 ... 312!8i6656
https://www.google.com/maps/@36.1700071 ... 312!8i6656
Also in Nashville, "Georgia RR"?
https://www.google.com/maps/@36.1393774 ... 312!8i6656
https://www.google.com/maps/@36.1396444 ... 312!8i6656
And finally, "CSX Transportation" in Nashville:
https://www.google.com/maps/@36.0884937 ... 312!8i6656
https://www.google.com/maps/@36.0887009 ... 312!8i6656
Sometimes you can find old railroad names on equipment, too. Not sure if SCL always did this, but a lot of equipment on the Port Tampa spur still has SCL markings on them:
https://www.google.com/maps/@27.9191797 ... 312!8i6656
NathanFromEngland
"Low Rat" at this motel along the Parkway here in Huntsville:
https://www.google.com/maps/@34.7452173 ... 312!8i6656
Just the one rat though.
ToledoRailfan
freebrickproductions wrote: Just the one rat though.
*For each room.
They're complementary! :LOL:
