Oky doky then.
Andrewsaxamophone
Oky doky then.
Post by Andrewsaxamophone »
Maybe the train is actually off the crossing, but it looks like it is, and that the lights are not on.
http://www.railpictures.net/viewphoto.p ... 877&nseq=2
Smjh1979
Site Admin
Re: Oky doky then.
Post by Smjh1979 »
I can't tell, unless the lights are in mid-flash?
Crossingman18
Re: Oky doky then.
Post by Crossingman18 »
well if you look in the picture, the ditch lights are not on, so the train isn't moving. My guess would be that the crew manually turned off the signals.
ER801
Re: Oky doky then.
Post by ER801 »
If a train stops on the approach, but hasn't reached the island, then the signals should reset and turn off. ...Rarely does a train crew interfere with grade crossing signals, except in switching operations and such. It is NOT a standard practice for a train crew member to "manually turn off" signals on a mainline.
Re: Oky doky then.
Here's another one on this same subject:
http://www.railpictures.net/viewphoto.php?id=267484
The train is clearly in the middle of that crossing, but the gate is up? :Confused:
I even left a comment on the picture asking if the road was closed or something but never got a response. Also, check out the odd bell placement on that signal.
SirKrunch
Re: Oky doky then.
Post by SirKrunch »
Interesting mounting of the bell there also, inbetween the two sets of lightheads...
:glare:
Well, :Censored:
Crossingman18
Re: Oky doky then.
there was a mini bell designed like the bell on the signal in the 2nd picture on Ebay. What made my head spin was someone was gonna pay over $380 for a mini bell that was to be mounted with 2 U bolts.
owensri
Site Admin
Re: Oky doky then.
Post by owensri »
Crossingman18 wrote:there was a mini bell designed like the bell on the signal in the 2nd picture on Ebay. What made my head spin was someone was gonna pay over $380 for a mini bell that was to be mounted with 2 U bolts.
Pretty outrageous... :Blink:
Andrewsaxamophone
Re: Oky doky then.
UPDATE:
Read the first sentance of the description in this picture.
http://www.railpictures.net/viewphoto.p ... 09&nseq=24
AndrewFields
Re: Oky doky then.
Post by AndrewFields »
I had a hunch this was the case. There is a second track in the street that we can't see because of the snow.
See here it doesn't look like it's used anymore.
You think your car gets bad mileage? SP 4449 consumes 10 gallons of bunker oil and 100 gallons of water every mile.
