Location of Crossing Railroads (Reserved Crossbucks)
- TrickyMario7654
Post locations of incorrectly installed crossbucks.
Schaefers Lane, Rosedale, Maryland.
https://www.google.com.au/maps/@39.3238 ... 312!8i6656
Eaton Street, Albion, Michigan.
https://www.google.com.au/maps/@42.2476 ... 312!8i6656
- ToledoRailfan
Re: Location of Crossing Railroads (Reserved Crossbucks)
I think I've posted that crossing before in Google Maps Scavenger Hunt but for the white and orange stripes on the bottom of the crossbuck post.TrickyMario7654 wrote: Eaton Street, Albion, Michigan.
- TrickyMario7654
Virginia Drive, Orlando, Florida.
https://www.google.com.au/maps/@28.5640 ... 312!8i6656
Interesting... if you go back to 2011, that side of the crossing looks a bit different. Kind of odd that the only upgraded one side, especially with the pole partially blocking the other mast signal: https://www.google.com/maps/@28.5640998 ... 312!8i6656TrickyMario7654 wrote:Virginia Drive, Orlando, Florida.
- TrickyMario7654
Let's go outside the US with this backwards crossbuck on the Weeroona Avenue level crossing in Bendigo, VIC.
https://www.google.com.au/maps/@-36.742 ... 312!8i6656
The stupid part is that when the crossing was gateless in 2010, the same cantilever had the crossbuck installed correctly.
V/Line, you had one job!
If you compare both years... the cantilever got moved further away from the tracks (to make room for the gate mast). So it could be a different cantilever. Or... at the very least they took all the signs off of it, then re-installed them in the process of moving it. Just a guess though...TrickyMario7654 wrote:Let's go outside the US with this backwards crossbuck on the Weeroona Avenue level crossing in Bendigo, VIC.
- TrickyMario7654
You could be onto something as I just noticed the SORS signs are different in both years.cabman701 wrote:If you compare both years... the cantilever got moved further away from the tracks (to make room for the gate mast). So it could be a different cantilever. Or... at the very least they took all the signs off of it, then re-installed them in the process of moving it. Just a guess though...TrickyMario7654 wrote:Let's go outside the US with this backwards crossbuck on the Weeroona Avenue level crossing in Bendigo, VIC.
2010: https://www.google.com.au/maps/@-36.742 ... 312!8i6656
2015: https://www.google.com.au/maps/@-36.742 ... 312!8i6656
So it may be a different cantilever as they usually like to tear everything out nowdays when they upgrade a gateless crossing with gates. Here's another crossing in the area that shows this.
2010: https://www.google.com.au/maps/@-36.705 ... 312!8i6656
2016: https://www.google.com.au/maps/@-36.705 ... 312!8i6656
Here's a backwards crossbuck install that is pure laziness!
Well,
"Hey boss, I accidentally installed the crossbuck and yield sign on opposite sides of the pole, what should I do?"SirKrunch wrote:Here's a backwards crossbuck install that is pure laziness!
"Just put it up with the yield sign facing traffic. It's Friday and I plan on being home and having a beer in 10 minutes and ain't nothin' gonna stop me now."
At least it's double sided...SirKrunch wrote:Here's a backwards crossbuck install that is pure laziness!
