US&S FN16a parts needed and a mount for my indicator lense
This part is for people who are looking for particular crossing signal parts or complete signals themselves. Do not put wayside signal parts in this forum.
jd318mike
Post by jd318mike »
I am hunting for the following parts for a US&S FN16a flasher relay. I need the two main coils, the top plate with the RF Choke coil that hangs in the middle and a stack of proper washers to set the flash rate. I am also hunting for the mount, I believe it was made by US&S, uses a thick clear glass fresnel lense that I have one of, mounted usualy upside down or the open end up. Around here they are mounted to a U shaped piece of conduit off the side or back of the relay case, it has 4 long machine screws with a cross plate to retain the lense to the mount. I wouldnt even mind having a whole 2 door relay case, i could put my crossing relays and power supply, as well as a few other items in there. Thanks Mike T
Due to economic conditions, the light at the end of the tunnel has been removed.
