Yea, though if it were still in service, I'm betting a lot of that classic stuff would be gone, or it would rarely see trains.dan the ca railfan wrote:if it is it reallysucks!!!!!!!!!!! lot of classic equiptment on that line.
Locations Of Currently Known WRRS Mini-M-Bells
Re: Locations Of Currently Known WRRS Mini-M-Bells
- dan the ca railfan
florida st. memphis tennesse
https://www.google.com/maps/@35.1184703 ... 312!8i6656
i believe i have found one on warford st. in memphis tn although it is hard to tell because the bell is painted red
https://www.google.com/maps/@35.1676202 ... 312!8i6656
very lucky to live two-three blocks away from three teardrop bells. one of which i see at least once a week!
Neither of those are mini-bells. The first is a WCH mechanical bell, and the second is a Modern Industries mechanical bell.dan the ca railfan wrote:florida st. memphis tennesse
i believe i have found one on warford st. in memphis tn although it is hard to tell because the bell is painted red![]()
Not sure about this one in Alma, Arkansas.
https://www.google.com/maps/@35.5262506 ... 312!8i6656
That appears to be a 1st Generation WCH mechanical bell.NathanFromEngland wrote:Not sure about this one in Alma, Arkansas.
- McK&H.Aust
Noticed that GSV has been updated and sadly those mini bells have been removed. The two bells on the median signals were replaced with pole caps, while the third one was replaced by a GS e-bell.ToledoRailfan wrote:Norton Shores, Michigan.
https://www.google.com/maps/@43.1872832 ... 6656?hl=en
https://www.google.com/maps/@43.1877622 ... 6656?hl=en
https://www.google.com/maps/@43.1873104 ... 6656?hl=en
I wonder if that GS E-Bell might be this bell, until it was replaced sometime in late-2013 or 2014 with a WRRS bell.McK&H.Aust wrote:Noticed that GSV has been updated and sadly those mini bells have been removed. The two bells on the median signals were replaced with pole caps, while the third one was replaced by a GS e-bell.ToledoRailfan wrote:Norton Shores, Michigan.
https://www.google.com/maps/@43.1877622 ... 6656?hl=en![]()
https://www.google.com/maps/@43.1873027 ... 6656?hl=en
There is also a video of the mini-bells in action, but the General Signals E-Bell is dead.
- McK&H.Aust
Interesting find there, I think the most recent e-bell has a fresher paint job so they are probably not the same. Wonder if the crossing originally had four mini bells? It's interesting that they bothered to remove the bells on the median signals and install pole caps, rather than disconnecting and leaving them in place.NathanFromEngland wrote:I wonder if that GS E-Bell might be this bell, until it was replaced sometime in late-2013 or 2014 with a WRRS bell.McK&H.Aust wrote:Noticed that GSV has been updated and sadly those mini bells have been removed. The two bells on the median signals were replaced with pole caps, while the third one was replaced by a GS e-bell.ToledoRailfan wrote:Norton Shores, Michigan.
Almost undoubtedly did. I believe Michigan required every signal at a crossing to have a bell.McK&H.Aust wrote:Interesting find there, I think the most recent e-bell has a fresher paint job so they are probably not the same. Wonder if the crossing originally had four mini bells? It's interesting that they bothered to remove the bells on the median signals and install pole caps, rather than disconnecting and leaving them in place.NathanFromEngland wrote:I wonder if that GS E-Bell might be this bell, until it was replaced sometime in late-2013 or 2014 with a WRRS bell.McK&H.Aust wrote:Noticed that GSV has been updated and sadly those mini bells have been removed. The two bells on the median signals were replaced with pole caps, while the third one was replaced by a GS e-bell.ToledoRailfan wrote:Norton Shores, Michigan.
out of service line in brewer maine which
sucks because the signal the mini bell is one has a cat-eye crossbuck
https://www.google.com/maps/@44.7798105 ... 312!8i6656
