Long Street, Lynn, AL
*originally recorded on 7-29-18*
Signal on the left: 2 pairs of Safetran 12x20 inch lights.
Signal on the right: 3 pairs of Safetran 12x24 inch lights, 1 pair of Safetran 12x20 inch lights, and a General Signals Type 3 electronic bell.
This was the only other crossing I recorded on July 29th, and while it probably isn't the most interesting crossing out there, it's certainly slightly unusual due to the left-hand signal using a 4 inch mast while the right-hand uses a 5 inch mast for some reason. Back in 2009, the right-hand signal had three pairs of Harmon 12x24 inch lights and 1 pair of Safetran 12x24 inch lights, likely due to a vehicle clipping the signal, while the bell was a Safetran mechanical bell facing away from the road, while the left-hand signal at this time had two pairs of Safetran 12x24 inch lights and 1 pair of Safetran 12x20 inch lights pointing to the right. Sometime between then and now, NS replaced all of the lights here and the bell, but for some reason, during the light upgrade, NS decided to remove the side lights and not replace them on the left-hand signal, even though East Main Street parallels the tracks on that side of the crossing here (West Main Street is the cross street in the foreground, confusingly enough). It also appears that the right-hand signal, still gets clipped occasionally, despite large concrete blocks being added next to the signal sometime within the past 9 years, as one of the lights had been hit and was cocked to the right when I was here. I'm honestly not sure if the pair of 12x20 inch lights on the right-hand signal (both of which are directly above/below one another) is due to a car/truck clipping the signal or not.
Re: Long Street, Lynn, AL
Filmed the other side here on 7-8-23:
http://www.rxrsignals.com/Alabama/G-Q/Lynn/Long/
*originally recorded on 2-28-26*
Signal on the left: 4 pairs of Safetran 12x20 inch lights with GE Uniform Look LEDs.
Signal on the right: 3 pairs of Safetran 12x24 inch lights with GE Uniform Look LEDs, 1 pair of Safetran 12x20 inch lights with GE Uniform Look LEDs, and a General Signals Type 3 electronic bell.
After catching the train in Natural Bridge, I continued chasing NS 320 down to this crossing for my eighth crossing I caught them at on this day, as I needed to get an updated video here as well.
Since I last recorded this crossing back in 2023, NS replaced the far signal here entirely with a new one. Not entirely sure why NS replaced that signal, though I suspect either the old one got hit, or NS wanted to add some side lights to that signal and the old mast wasn't tall enough for them. Either way, at about the same time, the closer signal was upgraded to LED as well. Nothing else appears to have changed to the closer signal though, thankfully.
https://www.rxrsignals.com/Alabama/G-Q/Lynn/Long/
