Locations Of Currently Existing Safetran Hybrids
- dan the ca railfan
Re: Locations Of Currently Existing Safetran Hybrids
very lucky to live two-three blocks away from three teardrop bells. one of which i see at least once a week!
Oddly enough, that used to be a one-way gated crossing!dan the ca railfan wrote:hazel st. danville il
https://www.google.com/maps/@40.1354806 ... 312!8i6656
https://www.google.com/maps/@40.1356146 ... 328!8i1664
Line must not get much use, if CSX felt they could safely downgrade it to a gateless install when converting it to two-way...
...And you were saying?freebrickproductions wrote:Oddly enough, that used to be a one-way gated crossing!dan the ca railfan wrote:hazel st. danville il
https://www.google.com/maps/@40.1353949 ... 312!8i6656
Yea, I'm pretty sure I mentioned that fact...NathanFromEngland wrote:...And you were saying?freebrickproductions wrote:Oddly enough, that used to be a one-way gated crossing!dan the ca railfan wrote:hazel st. danville il
Line must not get much use, if CSX felt they could safely downgrade it to a gateless install when converting it to two-way...![]()
AFAIK, Some quick FRA research shows the line is used 3 times a week, (Same compared to Fowler Avenue in Tampa) So i'd say the upgrade was nessecary.freebrickproductions wrote:Yea, I'm pretty sure I mentioned that fact...NathanFromEngland wrote:...And you were saying?freebrickproductions wrote:Oddly enough, that used to be a one-way gated crossing!dan the ca railfan wrote:hazel st. danville il
The second track where the switch is was OOS anyway.
https://www.google.com/maps/@40.1601394 ... 328!8i1664
Just as I suspected, and I could tell the second track was dead, as the switch had been removed.NathanFromEngland wrote:AFAIK, Some quick FRA research shows the line is used 3 times a week, (Same compared to Fowler Avenue in Tampa) So i'd say the upgrade was nessecary.freebrickproductions wrote:Yea, I'm pretty sure I mentioned that fact...NathanFromEngland wrote:...And you were saying?freebrickproductions wrote:Oddly enough, that used to be a one-way gated crossing!dan the ca railfan wrote:hazel st. danville il
Willing to bet CSX wouldn't have done anything had the road not gotten converted to carry two-way traffic.
parker st. waterloo iowa
https://www.google.com/maps/@42.5167241 ... authuser=0
martin luther king jr blvd waterloo iowa.
https://www.google.com/maps/@42.5033731 ... authuser=0
janesville iowa
https://www.google.com/maps/@42.6448889 ... authuser=0
could have sworn this one had been posted in this forum but it hasn't so here it is.
ia-188 plainfield iowa
https://www.google.com/maps/@42.8475194 ... 328!8i1664
