Both cantilevers are US&S. RACO cantilevers look noticeably different.
did raco produce cantilevers like that because i could have sworn there is a crossing in the centrral valley that has them!
i will check!
Griswold did, and RACO (and even Safetran a bit as well, it appears, IIRC) used the same splice boxes on the masts of their cantilevers as Griswold, for the most part. However, RACO didn't produce any cantilevers of that style, as by the time RACO came around, everyone had already moved onto other styles of cantilever.
Railroad probably moved the bell for some reason. I've seen it happen at another crossing before.
Looks like the mast is different in the 2017 view (or at least the lights are). Possible the mast was knocked over somehow, and they just moved the bell over.
