Google Street View
NathanFromEngland
Re: Google Street View
Post by NathanFromEngland »
A CSX container on a truck in Louisville, Kentucky.
https://www.google.com/maps/@38.2454041 ... authuser=0
busman_49
Post by busman_49 »
NathanFromEngland wrote:
dan the ca railfan wrote:
NathanFromEngland wrote:...This is probably the most confusing signal setup i've ever seen.
https://www.google.co.uk/maps/@42.24122 ... 312!8i6656
okay now that is confusing having five light heads instead of three.
plus why is the green light in the middle.
The signal is vertical, so the green goes in the middle, while the arrows go to the bottom, if the signal was horizontal, then the arrows would go to the 3rd and 4th section while the green itself goes to the 5th, here is an example of one in Tampa, Florida, this is under an overpass, so the signal is facing horizontally so drivers can see the signal property. This would avoid confusion with drivers in the straight lane becoming unsure on whether the signal is telling them to turn left.
https://www.google.co.uk/maps/@28.02264 ... 312!8i6656
Also, to answer your question on why there are five light heads (Aspects) that is because it is in a turning lane, so if they are to get a green arrow then they have the right of way, if the light is green but there is no arrow illuminated then you have to yield to other traffic to proceed safely, these are similar to your doghouse signals and your four aspect protected signals.
And being that it's Illinois, the fact that they require a minimum of two indications for each movement (I forget how exactly do describe it) means that both of the arrow signals are needed.
Post by ZachL »
NathanFromEngland wrote:A CSX container on a truck in Louisville, Kentucky.
Yes, CSX transports via truck as well...
NathanFromEngland
I am aware that CSX is not just a railroad company and CSX intermodal is a subsidary of CSX Corporation. :Roll:
NathanFromEngland
Post by ZachL »
NathanFromEngland wrote:This is pretty strange...
https://www.google.com/maps/@27.9591999 ... 6656?hl=en
...is everything unique strange to you?
NathanFromEngland
I'm just saying, why have a car park that is several inches close to tracks?
Wasn't like that in 2008.
https://www.google.com/maps/@27.9591502 ... 6656?hl=en
Post by ZachL »
...because the width of a train doesn't extend much further past the tracks and the parking stops are far enough away from the tracks?
dan the ca railfan
Post by dan the ca railfan »
well now i know what happens when you get pulled over in mn
https://www.google.com/maps/@44.3995413 ... authuser=0
Post by ZachL »
dan the ca railfan wrote:well now i know what happens when you get pulled over in mn
...the same thing that happens when you get pulled over in the other 49 states?
