Moderators: freebrickproductions , mlgillson , PlyingKibbles89 , Raco_GS , Hopen111 , TommyBNSF
NathanFromEngland
Posts: 2377 Joined: Sat Apr 29, 2017 3:52 pm
Post
by NathanFromEngland » Sat Jan 19, 2019 7:55 pm
freebrickproductions wrote:
Gate mech probably failed and the gate arm was removed.
Why couldn't they just chain the gates upright?
Posts: 9525 Joined: Thu Jun 07, 2012 11:12 am
Post
by freebrickproductions » Sat Jan 19, 2019 10:48 pm
Cheaper not to, or they mothballed the line in hopes of the line going back into service prior to abandonment, and then just had it abandoned when no service was going to return.
LARDLOGO
Posts: 844 Joined: Thu May 24, 2012 8:51 pm
Post
by LARDLOGO » Sun Jan 20, 2019 3:46 am
Slight update to the crossing at Bear Mountain Road in Arvin, California. The eastward signal has had all but one of it's lights removed. The gate had it's lights removed and it was also removed from the signal. It's hanging by the chain. The grade has also been poorly paved over.
https://goo.gl/maps/FqBwUnu9TZ82
NathanFromEngland
Post
by NathanFromEngland » Sun Jan 20, 2019 5:07 am
...and not too far away
https://www.google.com/maps/@33.6103254 ... 312!8i6656
Also i decided to keep on looking. Streetview however isn't reliable, as the pictures haven't been updated in a decade so i had to rely on Google Earth.
https://www.google.com/maps/@33.6030154 ... 328!8i1664
https://www.google.com/maps/@33.5884859 ... 328!8i1664
https://www.google.com/maps/@33.6175965 ... 312!8i6656
https://www.google.com/maps/@33.6321423 ... 328!8i1664
Remains of a small trestle.
https://www.google.com/maps/@33.6393121 ... a=!3m1!1e3
Another trestle, and what appears to be a relay case.
https://www.google.com/maps/@33.6466915 ... a=!3m1!1e3
After a while the line appears to head through the mountains, so i had to chase the remains of trackage to the nearest possible source.
https://www.google.com/maps/@33.8630535 ... 328!8i1664
Another trestle.
https://www.google.com/maps/@34.0262705 ... a=!3m1!1e3
...The line eventually seems to split into two and onto active railroad tracks, not sure if those new signals are even active at all, unless that remainder of the line is used for car storage.
https://www.google.com/maps/@34.0846961 ... 328!8i1664
On the other side.
Crossbuck crossing to the left, signals to the right.
https://www.google.com/maps/@33.5739307 ... 328!8i1664
Abandoned railcars?
https://www.google.com/maps/@33.5366423 ... a=!3m1!1e3
A WCH installation with E-Bells and WCH Clear LEDS.
https://www.google.com/maps/@33.5274029 ... 328!8i1664
freebrickproductions wrote: NathanFromEngland wrote: freebrickproductions wrote:
Back in 2013, the crossing was still recieving power until either the light failed or the relay case was eventually disconnected.
https://www.google.com/maps/@33.290857, ... 6656?hl=en
Posts: 3029 Joined: Mon Dec 17, 2012 4:04 pm
Post
by ZachL » Sun Jan 20, 2019 4:02 pm
Definitely disconnected. The gate is being held up to the mast, and naturally it would fall if there was no power.
Post
by ZachL » Mon Jan 21, 2019 8:32 pm
Interesting. The tracks' severance is the only sign it's out of service as well..
