CR 264, near Burnsville, MS
*originally recorded on 2-12-19*
Signal on the left: 2 pairs of Safetran 12x20 inch lights, a Safetran gate mechanism, and NEG gate lights.
Signal on the right: 2 pairs of Safetran 12x20 inch lights, a General Signals Type 2 electronic bell, a Safetran gate mechanism, and NEG LED gate lights.
Nothing really too much to say about this crossing either, as it's another early to mid-2000s NS install with both gate arms having been replaced, this time with only one set of gate lights that got replaced though. The reason why it activated was that a local freight pulled up close to the crossing, to stop on the main track at this siding, as the block signal just east of it was red. According to a signal maintainer that was sitting here, there was a local freight switching in Burnsville that was about to head back east to Sheffield, so I made my way back on over to Iuka after this...
Re: CR 264, near Burnsville, MS
*originally recorded on 6-10-26*
Signal on the left: 2 pairs of Safetran 12x20 inch lights, a General Signals Type 2 electronic bell, a Safetran gate mechanism, RECO LED gate lights, and an NEG LED gate light.
Signal on the right: 2 pairs of Safetran 12x20 inch lights, a Safetran gate mechanism, and RECO LED gate lights.
After catching 16Z in Wenasoga, I attempted to chase them back east to this crossing between Glen and Burnsville as I figured I'd have enough evening light left to film it with. However, when I got here, I found-out they were stopping to meet a 287. As a result, 16Z wound-up coming to a stop just before the crossing, with the conductor getting out to walk over to the switch so he could line it for 287 to go into the siding here. Because of the train getting close to the crossing, but not quite reaching it, the crossing activated but then timed-out after nearly two minutes.
After I filmed this crossing timing-out, 16Z's conductor got the switch lined for 287 to enter the siding to go around the mixed freight. As such, I was able to catch my sixth and final train of the day: NS 287 rolling with an ET44AC leading an AC44C6M for power as they slowly roll through the siding past 16Z.
A few seconds after 287 cleared and the absolute automatic signal at the east end of the siding had upgraded back to clear, 16Z's conductor lined the switch back for the main and engineer of the train throttled up the SD70ACe to continue the journey east. NS 16Z then slowly crawled across the crossing to pick-up the conductor before accelerating out of the siding and on east towards Sheffield Yard in Alabama. After catching both trains, however, I went back over to Corinth for supper and gas before returning home to Huntsville for the evening.
Since I last filmed this crossing back in 2019, the only notable change here appears to be that NS replaced most of the gate lights here with RECO LED gate lights. Thankfully, nothing else has changed to this early-2000s NS install since that video.
https://www.rxrsignals.com/Mississippi/ ... lle/CR264/
