Old rotating banner signal there.SirKrunch wrote:Valley Springs, SD
Tracks out of service
Steven429
Re: Tracks out of service
Was looking around on Google Maps recently when I found this out of service branch line in Waynesboro, GA, that lead to a now torn-down plant. Here's the line starting from the junction heading east:
This first crossing is a private crossing that doesn't appear to be protected by anything:
https://www.google.com/maps/@33.1001605 ... 312!8i6656
The next crossing has just four tracks and a pair of crossbucks:
https://www.google.com/maps/@33.1003254 ... 312!8i6656
After that is a 1990s NS install with an extra pair of crossbucks at it, for some reason:
https://www.google.com/maps/@33.0996238 ... 312!8i6656
The final road the tracks cross is the US 25 Bypass, which features a pair of cantilever signals installed by NS in the 1990s, though the tracks have been removed from the crossing:
https://www.google.com/maps/@33.0997345 ... 312!8i6656
There used to be the original Safetran mechanical bell here, back in 2011:
https://www.google.com/maps/@33.0994912 ... 312!8i6656
But by 2012, it had been replaced with the current General Signals (Type 2?) electronic bell:
https://www.google.com/maps/@33.0996611 ... 312!8i6656
Not entirely sure why, as it appears that the line was already dead by then.
- brett nc railfanner
8" Gateless signals in Middleton, Tennessee:
https://www.google.com/maps/@35.0424017 ... 328!8i1664
Down the line in Walnut, Mississippi, There are a pair of 8" signals with split crossbucks:
https://www.google.com/maps/@34.9461645 ... 328!8i1664
The crossings past have no streetview or has no streetview when the signals were around. The line goes active after that.
Cast iron crossbuck at that!brett nc railfanner wrote:Down the line in Walnut, Mississippi, There are a pair of 8" signals with split crossbucks:
Both are gone now, sadly.brett nc railfanner wrote:8" Gateless signals in Middleton, Tennessee:
(This was another post that got eaten by the forum earlier today.)
Here's an update to the out of service CSX Illinois Subdivision. Apparently they've started pulling the stored cars off of the line:
Several signalized crossings are shown in the video, though all of them are disconnected so they don't operate. I'll see about following the line on Google Maps and make a post about it later.
Also, this crossing in Chattanooga, TN appears to be out of service:
https://www.google.com/maps/@35.0553336 ... 312!8i6656
- Ethan the Railfanner
The standard Blue ENS DOT tags retain there too!freebrickproductions wrote:Also, this crossing in Chattanooga, TN appears to be out of service:
https://www.google.com/maps/@35.0552814 ... 312!8i6656
Ethan the Railfanner; The main railroad crossing photographer of Southeast United States, while also slowly expanding elsewhere across the U.S.
If you have any crossing photos that you would like for submissions:
DM me on the forum
DM me on Discord (ethantherailfanner)
DM me on the forum
I believe DOT tags still remain up-to-date so long as a line is not officially deemed "abandoned" which is different from out of service.Ethan the Railfanner wrote:The standard Blue ENS DOT tags retain there too!freebrickproductions wrote:Also, this crossing in Chattanooga, TN appears to be out of service:
https://www.google.com/maps/@35.0553336 ... 312!8i6656But too bad it's out of service, as you see here:
Florence, South Carolina:
https://www.google.com/maps/@34.208742, ... 312!8i6656
